Dunavin’s OTop 8 build
J_Dunavin
Re: Dunavin’s OTop 8 build
#16 Post by J_Dunavin »
Woofer spacers
:cussing: I set these down and put some 5 lbs weights on them, but they slid :chainsaw: PL works really good :roll:
Nothing a little belt sander can't fix
Could not be happier with the progress tonight! I test fit the pieces and everything fits reaaal nice!
Actually fit so good, i was able to pick it up as seen here.
I will have to do a bit of clean up on the edges were the woofer holes meets the horn. Nothing a Dremel tool can do.
Should look like a could of speaker boxes tomorrow.
J_Dunavin
#17 Post by J_Dunavin »
A few more photos.
Test fit all the driver hardware, before glueing the top and bottoms, glued top, bottom and horn sides. I did the horn to side braces after the fact, so I could trim to fit.
Tacked on the skill saw guide and trimmed off the horn sides, not as smooth as I was hoping for, should if used a better blade, nothing some wood filer and black paint can’t fix. And finally test fit the sides! Starting to look like something!
ACUA
#18 Post by ACUA »
I enjoy the pictures, looks really good. Wish I had a table saw with a sled.
#19 Post by Seth »
Awwwwww heck yeahhhhhh!!!
Coming together with a swiftness :thumbsup:
J_Dunavin
#20 Post by J_Dunavin »
ACUA wrote: Mon Apr 11, 2022 8:35 am I enjoy the pictures, looks really good. Wish I had a table saw with a sled.
Thanks!
You should make your own sled! There are a ton of how to videos out there. Those rails are just “T slot” rails from McMaster Carr, and some 1/4 -20 bolts with plastic knobs that have a 1/4-20 insert, so I can hold stuff down.
It was really cheap to make and it’s getting pretty beat up, so I don’t feel bad about making a new one… mostly from scraps I already have.
J_Dunavin
#21 Post by J_Dunavin »
Seth wrote: Mon Apr 11, 2022 9:02 am Awwwwww heck yeahhhhhh!!!
Ugh, nothing like a deadline to kick things into high gear.
I have a minimum amount of Birch though so I really have to measure like three times and make sure I’m making the right cuts.
Now is not the time for a mistake 😬
Edit.. I also had played with cut list to make sure I was maximizing T39 width for the four sheets of 5’x 5’ birch I bought. With the scraps I have plus the full sheets, I should be able to get two 20” cabs. Was previously planning on two 18” wide. Not sure if that’s a audible difference, but every inch counts I suppose.
#22 Post by Bruce Weldy »
Excellent work! Looking good.
J_Dunavin
#23 Post by J_Dunavin »
Thanks Bruce!
#24 Post by Tom Smit »
Memory is failing. Is this the first Otop8 build thread?
#25 Post by Seth »
I know there were some other threads and people who built them. However, I don't recall whether there was an actual build thread that went along with any of them. It may be you're right! (my memory is failing too LOL)
Edit to add: Just did a more thorough search and didn't find a single one. Joe! You're the first! By the way, did you decide to take on using the adjustable top hat's?
J_Dunavin
#26 Post by J_Dunavin »
I wish I was the 1st, but this guy built a pair along with some T48s. I messaged him and he’s loving them.
viewtopic.php?f=30&t=25234&start=45
I really wanted to go for the fatal pro drivers, but that would have been some serious cash.
Seth, I thought about the adjustable top hats, they would have been cool, but they are actually hard to find now and I figured it was one more thing to break.
Anyway thanks for the comments! These are lots easier than DR200s 😁
#27 Post by Tom Smit »
Tom Smit wrote: Mon Apr 11, 2022 9:32 pm Memory is failing. Is this the first Otop8 build thread?
J_Dunavin wrote: Mon Apr 11, 2022 10:44 pm I wish I was the 1st, but this guy built a pair along with some T48s. I messaged him and he’s loving them.
I just read that thread! Thanks Grey Owl for commenting on it! That thread became first for reading when I logged in.
J_Dunavin
#28 Post by J_Dunavin »
Practiced cutting out the throat reflectors tonight, not fun but I think I have a decent path for cutting the 65 deg angle.
Also glued the sides on! Looks like a box now… all down hill after these throat pieces.
J_Dunavin
#29 Post by J_Dunavin »
Don't try this at home kids! I made the large angle cut by flipping the piece up 90deg and then tilting the blade over 25 deg. I made the pieces larger than i needed and made this cut first as i had to make several passes. Then i came back, measured the distance to the other cut and made it since it can easily be made with the fence.
I also cleaned up the inside corners where the back plate doublers are going.
back panel set back.jpg (10.39 KiB) Viewed 134361 times
65deg cut.jpg (15.6 KiB) Viewed 134361 times
horn throat.jpg (8.95 KiB) Viewed 134361 times
horn throat up close.jpg (6.92 KiB) Viewed 134361 times
#30 Post by Seth »
Real nice fit. Looks great :thumbsup:
