Page 2 of 3
Re: First build 24" thtlp!
Posted: Tue Mar 03, 2020 11:44 pm
by -Russian-spy-
Anyone have input? I should be moving forward on thursday, the error is located where closest clamp in the bottom of the last picture. Hopefully it isnt to much to worry about.
Posted: Wed Mar 04, 2020 7:27 am
by Bryan Cox
-Russian-spy- wrote: ↑Tue Mar 03, 2020 11:44 pm
Never built this cab, but I did have the same issue on one of my T39s. I'm sure if the distance between panels 4 and 7 were decreased significantly then your SPL would suffer. And I'm no Bill, but I think you're fine.
The T39 that I experienced this issue with did not suffer any degradation. Maybe Bill will chime in with some science.
Posted: Wed Mar 04, 2020 9:28 am
You might have a bit of challenge when you install panel 8 (and 10), but it won't make much of a difference sonic-ally.
Posted: Wed Mar 04, 2020 10:41 am
Sound waves hate symmetry, so from that standpoint you're better off not having everything perfectly square and true.
Posted: Sat Mar 28, 2020 2:56 pm
by -Russian-spy-
Bill Fitzmaurice wrote: ↑Wed Mar 04, 2020 10:41 am
I've been going over the plans, and I seemed to have missed the memo of braces being no more than 8 inches apart, I placed the 1/7 and 1/8 braces 9-10 inches apart. Would I be best off leaving it be? Or adding another brace in between them?
Posted: Sat Mar 28, 2020 10:03 pm
I'd throw one in there just so that there would be no regrets down the road....you know....you wonder if it might be a little better if that brace was actually installed.
Posted: Sun Mar 29, 2020 7:46 am
You can't have too many braces, you can have too few.
Posted: Mon Mar 30, 2020 10:45 am
by -Russian-spy-
Thanks for the input and guidance guys, some progress has been made! I decided to use extra bracing on all the interior panels, things are shaping up nicely so far
Posted: Mon Mar 30, 2020 10:15 pm
Right on!
Posted: Tue Mar 31, 2020 5:02 am
by Seth
Heck yeah. Looking good
Posted: Fri Apr 03, 2020 4:59 pm
by -Russian-spy-
Getting a bit closer, had a bit of trouble getting the last panel on, pretty sure I had the same twisting issue another member had, but I managed to pull everything pretty close. I also should have paid better attention when installing some braces, I pushed panel 1 out of alignment a bit causing a bulge in the middle, but I was still able to clamp it flush. Anyway things are going fairly smooth, have all the braces cut/installed in the driver chamber
Posted: Fri Apr 03, 2020 5:02 pm
by -Russian-spy-
I also have a question about bracing the mouth, I really like the look of these curved braces I made, any reason this would not be a wise idea?
Posted: Tue Apr 07, 2020 10:00 am
by -Russian-spy-
All sanded and ready for stain
Posted: Tue Apr 07, 2020 2:11 pm
by Rich4349
Beautiful!
Posted: Tue Apr 07, 2020 9:13 pm
That's a wild finish!
