Tuba 30 bass sick Dual kappalite 3012LF
Re: Tuba 30 bass sick Dual kappalite 3012LF
#16 Post by Bruce Weldy »
Rickwired wrote: Mon Jan 14, 2019 12:00 am Ordered the PA2 should be here in time for this weekend. Any suggestions on high and low pass freqs for these? 2 - dual loaded 3012LF gonna be using them with a pair of mackie srm450. I’m new to this type of sub... I usually just have a powered qsc kw181.
More importantly, you must set the limiters properly to protect the drivers. 50 volts max coming out of the amp. And personally, I wouldn't let them get below 35hz regardless of the number of subs. Excursion kills drivers.
The 2 subs will be more than enough to run past those Mackies. V-plate 'em for extra db and place 'em correctly - you'll be just coasting.
Rickwired
#17 Post by Rickwired »
Damn it sounds so good! Like toooooo good
4- 29” tuba 30 w/ dual kappalite 3012lf
2 - 18” tuba 30 w/ 3012lf
4 - OT12 w/ 3012HO and crossfiring tweeter array
2 more OT12 w/ 3012HO and tweeter arrays in progress
#18 Post by CoronaOperator »
:clap:
Now you know what we get all excited about! Wait until you build some tops to match!
