Page 2 of 6
Re: Otop Jarray build x 4
Posted: Sat Nov 03, 2018 10:55 pm
Cool.
What is the brand name of the purple primer?
Posted: Sun Nov 04, 2018 8:58 am
PVC cement primer may be clear or colored. The advantage to colored is you can see on PVC pipe where it's been applied, so you don't miss a spot. The same applies to the cement. Colored cement is usually orange.
Posted: Sun Nov 04, 2018 6:03 pm
by himhimself
CPVC plumbing has to have primer. I was told the purple allows home inspectors to visually verify plumbing connections were correctly assembled. Big box stores often sell little packs of primer and cement for pretty cheap. Everytime I've bought a larger cement, it always goes bad.
Posted: Sun Nov 04, 2018 6:44 pm
Thanks.
Posted: Sat Apr 27, 2019 12:05 pm
by himhimself
Got the basic boxes assembled this morning. My pin nailer made it pretty easy, although I still get pl all over myself. Next to trim the height of my baffles to fit, as I made them a little tall not knowing exactly how close the boxes would be to the plans. And I don't want to mess around adding little strips like I had to do with the sides.
Posted: Sun Apr 28, 2019 8:45 am
by ACUA
Dude you got pl on my phone man what the heck!
Posted: Sun Apr 28, 2019 3:41 pm
by himhimself
Sorry bro... here ya go
Posted: Sun Apr 28, 2019 8:08 pm
by himhimself
Baffles and spacers glued up, got one mounted in the box. That'll be it for this weekend. Tubas ran for 6 hours last night without a hitch, just effortless bottom end
Posted: Thu May 02, 2019 7:39 pm
by himhimself
A little more progress. Got the middle braces installed tonight. I'm happy with the way I left the full length of the triangle as it's made the sides super stiff. Same with the woofer spacer running the full width of the baffle Had to do a little torquing to get the boxes nice and square before gluing and pinning, but they seem pretty straight now. Hope to get a bit further this weekend since I'll be traveling a good chunk of this month.
Posted: Fri May 03, 2019 9:11 am
by ACUA
Wow so jelly man!
Posted: Fri May 03, 2019 8:58 pm
by himhimself
Made my rear side and top braces tonight. Hope to cut the bendy horn sheathes tomorrow and start gluing them in. Checked my stock of panel mount neutrik speak on jacks and don't have enough so ordered 8 of the round plate type from Amazon the otops. The panel ones will go on the next pair of tubas and a amp rack panel some day. Empty boxes right now weigh 11.5 lbs. Hoping to come in under 30 when complete.
Posted: Sat May 04, 2019 7:42 am
by Chris_Allen
I can almost smell the cut plywood....
Posted: Sat May 04, 2019 11:46 am
by himhimself
A little more progress...
Posted: Sat May 04, 2019 11:52 am
by himhimself
Only enough clamps to do one at a time. Just as well, as the sheaths seem to have a little gap to the braces after I got them all clamped down. Crud. I trust the PL will expand enough to take up the space. If not, I suppose I can put some PL from the backside after they cure. The other 6 sheaths are ratchet strapped around a log to get some pre-bend into them so they will lay down easier. I made some spacers to hold the narrow ends in place by the baffle rather than try to nail/clamp them. Seems to be working okay. The blue and red clamp combo is attempting to pull a slight bend out of the top panel.
Posted: Sat May 04, 2019 12:05 pm
by himhimself
You also may notice I didn't cut the handle ports or drill the holes for the tee-nuts. Not an oversight. I was concerned that if the cabinets came out a little wonky, they wouldn't look right when clamped into an array. Once all the sheaths are on and trimmed, I have a template I can place on the side and get the 4 holes all in exact same spot. Actually probably was an unnecessary adventure as the cabinets seem to be more square than my skills warranted - Yay!
