What is the minimum lenght of wire when splitting speaker?
Rich4349
Re: What is the minimum lenght of wire when splitting speaker?
#16 Post by Rich4349 »
Bill Fitzmaurice wrote:
J_Dunavin wrote:This may be of help....
http://www.electrovoice.com/cableloss.php
It would be if it actually told you what the result of a given insertion loss would be, but it doesn't. This does:
http://www.bcae1.com/images/swfs/speake ... istant.swf
Bill, when I click on your link it leads to non-electronics types of insertion. Was that an intentional joke?
#17 Post by Bruce Weldy »
Rich4349 wrote:Do many of you guys run 10ga or more on runs > 25 feet? Where could one find ready made cables this size?
I doubt you'll find anyone running 10 gauge on this forum. Every cable I have is 12ga....regardless of length. 12ga. is fine to 50 feet. But, I can't remember the last time I had to go that far in a setup.
If you are running shows big enough where you need to get over 50 feet, you should have an amp rack for each side of the stage anyway.
Rich4349
#18 Post by Rich4349 »
If you were running two amp racks how would you share a common ground to reduce ground loop hum? (Not to derail the thread.)
Rich4349 wrote: Bill, when I click on your link it leads to non-electronics types of insertion. Was that an intentional joke?
You must be using a PDA, not a computer.
You won't have ground loop issues using only balanced connections.
http://www.rane.com/note110.html
BrentEvans
#20 Post by BrentEvans »
It's not necessary. My FOH goes through 100' of 12/8 followed by short jumpers of 12/4. I calculated insertion loss to be 1-2db with that combination, which is fine. I've got NL8 couplers to go out to 200' if I need to, which we do at least once a year. Never had any issues.
NL4 connectors are optimized for #12 wire. If you want to use #10 (which really isn't "necessary" until you get the 200 foot length) you'll have to clip some of the wire to get it in the connector. Stick with #14 for less than 50 foot lenghts, #12 out to 100 ft. You can buy perfectly good rubber jacketed wire from Amazon for relatively cheap and make your own. That link isn't the only product out there, but I've used it and it works well.
J_Dunavin
#21 Post by J_Dunavin »
Bill,
How do we fix it that link?
Not work safe :( :(
#22 Post by Bill Fitzmaurice »
J_Dunavin wrote:Bill,
The link is not ours to fix. When you use a computer to go to it there's no problem. What it does with other devices I can't say. I don't own any.
#23 Post by Bruce Weldy »
+1 worked fine from my computer
philrev
#24 Post by philrev »
Thanks everybody answering my questions, nice to be here in this forum.
Rich4349
#25 Post by Rich4349 »
The link is so long that it gets abbreviated with "****" , literally, in the middle. If anyone with access to the unedited link cared to they could make a shorturl for it.
#26 Post by Bill Fitzmaurice »
Rich4349 wrote: The link is so long that it gets abbreviated with "****" , literally, in the middle
That doesn't affect anything. This is the address, less the www prefix:
bcae1.com/images/swfs/speakerwireselectorassistant.swf
