Bill, when I click on your link it leads to non-electronics types of insertion. Was that an intentional joke?Bill Fitzmaurice wrote:It would be if it actually told you what the result of a given insertion loss would be, but it doesn't. This does:J_Dunavin wrote:This may be of help....
http://www.electrovoice.com/cableloss.php
http://www.bcae1.com/images/swfs/speake ... istant.swf
What is the minimum lenght of wire when splitting speaker?
Re: What is the minimum lenght of wire when splitting speaker?
I doubt you'll find anyone running 10 gauge on this forum. Every cable I have is 12ga....regardless of length. 12ga. is fine to 50 feet. But, I can't remember the last time I had to go that far in a setup.Rich4349 wrote:Do many of you guys run 10ga or more on runs > 25 feet? Where could one find ready made cables this size?
If you are running shows big enough where you need to get over 50 feet, you should have an amp rack for each side of the stage anyway.
If you were running two amp racks how would you share a common ground to reduce ground loop hum? (Not to derail the thread.)
You must be using a PDA, not a computer.Rich4349 wrote: Bill, when I click on your link it leads to non-electronics types of insertion. Was that an intentional joke?
You won't have ground loop issues using only balanced connections.If you were running two amp racks how would you share a common ground to reduce ground loop hum? (Not to derail the thread.)
http://www.rane.com/note110.html
- BrentEvans
It's not necessary. My FOH goes through 100' of 12/8 followed by short jumpers of 12/4. I calculated insertion loss to be 1-2db with that combination, which is fine. I've got NL8 couplers to go out to 200' if I need to, which we do at least once a year. Never had any issues.Rich4349 wrote:Do many of you guys run 10ga or more on runs > 25 feet? Where could one find ready made cables this size?
NL4 connectors are optimized for #12 wire. If you want to use #10 (which really isn't "necessary" until you get the 200 foot length) you'll have to clip some of the wire to get it in the connector. Stick with #14 for less than 50 foot lenghts, #12 out to 100 ft. You can buy perfectly good rubber jacketed wire from Amazon for relatively cheap and make your own. That link isn't the only product out there, but I've used it and it works well.
Bill,
How do we fix it that link?
Not work safe
Not work safe
The link is not ours to fix. When you use a computer to go to it there's no problem. What it does with other devices I can't say. I don't own any.J_Dunavin wrote:Bill,
+1 worked fine from my computerBill Fitzmaurice wrote:The link is not ours to fix. When you use a computer to go to it there's no problem. What it does with other devices I can't say. I don't own any.J_Dunavin wrote:Bill,
Thanks everybody answering my questions, nice to be here in this forum.
The link is so long that it gets abbreviated with "****" , literally, in the middle. If anyone with access to the unedited link cared to they could make a shorturl for it.Bill Fitzmaurice wrote:The link is not ours to fix. When you use a computer to go to it there's no problem. What it does with other devices I can't say. I don't own any.J_Dunavin wrote:Bill,
That doesn't affect anything. This is the address, less the www prefix:Rich4349 wrote: The link is so long that it gets abbreviated with "****" , literally, in the middle
bcae1.com/images/swfs/speakerwireselectorassistant.swf
