Nice work.
36" THT Low Profile, Warning lots of coffin pictures
- Scott Brochu
Re: 36" THT Low Profile, Warning lots of pictures
Should be called the coffin.
Nice work.
Nice work.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
Re: 36" THT Low Profile, Warning lots of coffin pictures
Routed some bevels
And some painting
It´s really matte black... when it dries.
Hopefully today after two coats of paint i will do some testing and measuring
Hopefully, you did horn path leak testing before painting....El dillo wrote:Hopefully today after two coats of paint i will do some testing and measuring![]()
Nice build, BTW.
Yes, as good as i could with a shorter piece of tube.Hopefully, you did horn path leak testing before painting....![]()
Nice build, BTW.
Should be all you need. 10V@20Hz will really show even the slightest of air leaks.El dillo wrote:Yes, as good as i could with a shorter piece of tube.
Please do the forum a small favor and fill out your location in the User Control Panel, located in the top right hand corner of every page.
Are you going for that glossy, piano black finish? I can only dream of being able to do a finish like that.
Some garage measurements...
REW and calibrated UMIK-1
No expert so i apreciate tips on how to do this right...
THTLP on saw horses 1,5m from walls - mic exact infront of mouth, Volts... don't remember (very low).
THTLP on saw horses 1,5m from walls - mic 1meter infront of mouth, Volts... don't remember (very low).
I also did some dB meter readings (not calibrated)
@ 5 volts
50hz @ 95 dB
40hz @103,9 dB
30hz @ 99 dB
25hz @ 95,1 dB
20hz @ 93,4 dB
@ 17,3 volts (max output from amp)
40hz @ 113,9 dB
32hz @ 112,1 dB
Sweep 10-100hz peaked @ 117,4 db
will try to do some measurements in livingroom corner loaded later.
Measure with the subs on the floor, against the wall, and the mic an inch above the floor. You'll still have peaks and valleys, caused by room reflections.
Ok, will try that instead.
Against the wall, as in mouth facing the wall, standard use position? Then place the mic between the mouth and the wall?Bill Fitzmaurice wrote:Measure with the subs on the floor, against the wall, and the mic an inch above the floor. You'll still have peaks and valleys, caused by room reflections.
With mouth 18" from wall facing wall or mouth facing along the wall?
OK...
Its huge and space is tight
Let's see how it ends...
Only if that's your usual listening position.Rich4349 wrote: Then place the mic between the mouth and the wall?
If you're taking indoor measurements what matters is response at the listening position with the speakers placed where they give the best result.
Thanks got confused Indoor/outdoor
10-150hz sweep, mic @ listening position and horn cornerloaded
Stratispho
El dillo wrote:Its huge and space is tight
Current HT Setup
TV - Vizio e701i-a3
Denon AVR-X2000
9 driver Curved SLA center channel
Rebuilt Bose 4000 L/R
Single 4" rears
Table Tuba w/ MCM 55-2421
TV - Vizio e701i-a3
Denon AVR-X2000
Single 4" rears
