36" THT Low Profile, Warning lots of coffin pictures
Scott Brochu
Re: 36" THT Low Profile, Warning lots of pictures
#16 Post by Scott Brochu »
Should be called the coffin. :loler:
Nice work.
Drumming is a way of life.
ME LIKE TO HIT THINGS!
El dillo
Re: 36" THT Low Profile, Warning lots of coffin pictures
#17 Post by El dillo »
:lol: it surely look like a coffin...
Routed some bevels
And some painting
It´s really matte black... when it dries.
El dillo
#18 Post by El dillo »
Hopefully today after two coats of paint i will do some testing and measuring :hyper: :D
#19 Post by DJPhatman »
El dillo wrote:Hopefully today after two coats of paint i will do some testing and measuring :hyper: :D
Hopefully, you did horn path leak testing before painting.... :bash: :slap: :chainsaw: :loler:
Nice build, BTW.
El dillo
#20 Post by El dillo »
Nice build, BTW.
Yes, as good as i could with a shorter piece of tube.
#21 Post by DJPhatman »
El dillo wrote:Yes, as good as i could with a shorter piece of tube.
Should be all you need. 10V@20Hz will really show even the slightest of air leaks.
Please do the forum a small favor and fill out your location in the User Control Panel, located in the top right hand corner of every page.
Are you going for that glossy, piano black finish? I can only dream of being able to do a finish like that.
El dillo
#22 Post by El dillo »
Some garage measurements...
REW and calibrated UMIK-1
No expert so i apreciate tips on how to do this right...
THTLP on saw horses 1,5m from walls - mic exact infront of mouth, Volts... don't remember (very low).
THTLP on saw horses 1,5m from walls - mic 1meter infront of mouth, Volts... don't remember (very low).
I also did some dB meter readings (not calibrated)
@ 5 volts
50hz @ 95 dB
40hz @103,9 dB
30hz @ 99 dB
25hz @ 95,1 dB
20hz @ 93,4 dB
@ 17,3 volts (max output from amp)
40hz @ 113,9 dB
32hz @ 112,1 dB
Sweep 10-100hz peaked @ 117,4 db
will try to do some measurements in livingroom corner loaded later.
Measure with the subs on the floor, against the wall, and the mic an inch above the floor. You'll still have peaks and valleys, caused by room reflections.
El dillo
#24 Post by El dillo »
Ok, will try that instead.
Rich4349
#25 Post by Rich4349 »
Bill Fitzmaurice wrote:Measure with the subs on the floor, against the wall, and the mic an inch above the floor. You'll still have peaks and valleys, caused by room reflections.
Against the wall, as in mouth facing the wall, standard use position? Then place the mic between the mouth and the wall?
El dillo
#26 Post by El dillo »
With mouth 18" from wall facing wall or mouth facing along the wall?
El dillo
#27 Post by El dillo »
OK... :? Its huge and space is tight :(
Let's see how it ends... :cowboy:
#28 Post by Bill Fitzmaurice »
Rich4349 wrote: Then place the mic between the mouth and the wall?
Only if that's your usual listening position. :shock:
If you're taking indoor measurements what matters is response at the listening position with the speakers placed where they give the best result.
El dillo
#29 Post by El dillo »
Thanks got confused Indoor/outdoor :noob:
10-150hz sweep, mic @ listening position and horn cornerloaded
Stratispho
#30 Post by Stratispho »
El dillo wrote:Its huge and space is tight
:loler:
Current HT Setup
TV - Vizio e701i-a3
Denon AVR-X2000
9 driver Curved SLA center channel
Rebuilt Bose 4000 L/R
Single 4" rears
Table Tuba w/ MCM 55-2421
