Preferred method of cutting metal grilles
- Hackomatic
Re: Preferred method of cutting metal grilles
FWIW, when I cut the stainless grills for the Simplexx subs I did use a metal cutting blade in the table saw. And although I got them cut, I wish now I would have done something different. It is a challenge to keep the thin, bendy grill flat on the table and tight to the fence. PLUS, you end up with raised, razor sharp edges after cutting that need a pass with the grinder. Wear gloves or your hands will be ribbonized . . .
Dave H
- Chris_Allen
Ribbonized. Verb of the day.
- BrentEvans
My preferred method is going to the local metal shop with dimensions. 24 hour turnaround if you pick stock from their in hand and usually discount priced that way too. Think I paid $25 ea for my dr200 grills (bent on all for sides for looks) and about $35 ea. for something subwoofer sized. Both in nice punched metal, thick stuff. Not expanded or the thin stuff on commercial cabs.
