First proper outing for the rig :)
chrisj360
Re: First proper outing for the rig :)
#16 Post by chrisj360 »
Great review! Nice to hear the feedback as I am itching to get my two tuba's some performance time in the near future.
Here's something I discovered while playing around with the spl charts awhile back:
One T30 with two 2010's has almost the same output as the T39 while still going lower, with the exception just in the 40-55 hertz range. Seriously considering doing this for my next tuba build. They would only add 8 pounds of weight to the build instead of the 25 pounds for the Lab12. A few dollars more however.
Thoughts on this anyone?
I love listening to my d&b through my tubas and otops at my house, never heard some of these songs so clean sounding.
2 x 21" T30's with Lab12's
2 x 28" T30's with Lab12's
escapemcp
#17 Post by escapemcp »
I'm liking that output from just a 24" cab... my 2 wider cabs are 24" and have the labs in them - never even knew you could use 2 10" drivers. Does anyone know the voltage limit is on the dual S2010 please (per driver)? I'm interested, although I'd have to keep the subs on totally different channels (possibly using speakon-8s on the dual driver cabs to avoid any confusion)
EDIT: Only 3.5mm xmax :confused: I'm guessing that even though they are more sensitive, you wouldn't want to put much power through these to get to Lab12/3012 sort of SPLs! Can anybody clarify please. thx
#18 Post by Grant Bunter »
The S2010 is limited to 27V IIRC.
The BP102 8 ohm is limited to 35V, the 4 ohm version is less than that.
When you dual load you also need to rethink when it comes to impedance loading and cab counts/channel, and the way you wire them internally and together.
It has also been said in the past, that wiring in series (internaly) and then blowing a driver can be a disaster.
Great review escapement :)
escapemcp
#19 Post by escapemcp »
Grant Bunter wrote:The S2010 is limited to 27V IIRC.
NL8's were going to be my friend if I took this route... I think I have already decided against it with those low limits though.
Grant Bunter wrote:It has also been said in the past, that wiring in series (internaly) and then blowing a driver can be a disaster.
Another reason to stick with the Lab12 option.
Grant Bunter wrote:Great review escapement :)
Thanks Mr. Butler :slap: :bash:
For those of you who are wondering (probably nobody) my name comes from an old Commodore64 game (based on Tron). The game was pretty awful to be honest (even though I played it loads!). I was looking for a 'name' when I first came onto the internet I wanted something pretty unique (to avoid clashes with other people). For some reason on that particular day, I was thinking of that game - it could have easily been another game - like Blagger64 or Falcon Patrol - or something else equally as random.
chrisj360
#20 Post by chrisj360 »
I apologize for the dual 10's post, I hadn't had a chance to fully research that thought beyond the spl charts. Thanks for clearing that up Grant, I guess for my next build I'll be sticking with the Lab12's.
Escape: If you can describe it, what was it about the sound that evening that made you consider building a pair of titans rather than just another pair of tuba's? Was it just not loud enough or mainly just better pack space for transport in regards to spl? Etc?
I am curious mainly because even though I am super stoked on how my 28" tuba's came out and sound, I keep wondering if I should have built the titans instead. I've been having an internal debate for awhile now (see http://billfitzmaurice.info/forum/viewt ... =1&t=21441 ) about either ordering the titan plans and building a pair or just building another pair of tubas. I love how clean and low the tubas go and initially I wanted to go for clean full bass, rather than just loud. But I've been to a few other shows recently where it just seems like the audience wants stupid loud, regardless of the hearing damage they are being subjected to.
My intentions aren't to hijack the thread or start another tuba vs titan debate. I would just really appreciate some input from another fellow tuba builder (non-T60 because it's not fair to compare the T30 to a T60). I know that don and a few other tuba builders are still super happy with their systems, as I am but it seems that we both dj more similar music. But with the ratio of titan to tuba builders (once again non T60), I am curious if I should have built the titans.
One thought though, when I was building my tubas I had some issues with rubbing on the baffle that lead me to repeatedly removing the driver, sanding, remounting, checking and then starting the process over again. After some time, a number of the holes for driver recex screws became stripped out so be careful with how many times you would potentially swap out your drivers between the different cabinets. I don't know if it was just user error on my part but wanted to share my experience.
I very much remember that game you based your handle on. My favorite was pitfall and qbert as a kid.
Sorry for the long winded post, I didn't mean for it get this big.
Cheers.
#21 Post by Grant Bunter »
escapement:
I remember the original Tron movie, seems like decades ago. Wait about, it bloody was decades ago lmao!
Never got in to Commodore 64. Great info all the same.
chrisj360:
No need to apologise whatsoever!
TBH, there is a place for dual loading cabs. This is only my opinion, but to get the most cabs per channel per amp, you have to manipulate impedance with series wiring dual loaded cabs and paralleling them together.
Most of us simply aren't in the league required to consider doing it though.
It would be fun to have 16 premium 8 ohm driver dual loaded cabs on 2 amps though wouldn't it :)
There are pros and cons to every decision. When you make the decision to go a certain way, you also have to take what may go with that decision, ie potential series wiring issues with blown driver, and a domino effect.
Let's look at it realistically though.
A lab 12 single loaded cab is good for 50V limited, relating back to the chart you provided, same as the 3012lf.
A dual loaded S2010 serial wired cab is good for 54V, but not significantly greater output.
In fact, while the dual loaded T30 has more extension than the T39, the outband band you mentioned is nearing 3dB higher in the T39. That 3dB = 1 extra T30 cab in the stack to address the difference. So more drivers, ply, PL, time, cabling, possibly another amp.
And finally, it's pretty much moot, because if you were looking for lower than 40Hz, you wouldn't build T39's anyway.
Sorry for the sidestep...
escapemcp
#22 Post by escapemcp »
chrisj360 wrote:Escape: If you can describe it, what was it about the sound that evening that made you consider building a pair of titans rather than just another pair of tuba's? Was it just not loud enough or mainly just better pack space for transport in regards to spl? Etc?
Where do I start??!! The plan was always to build several different subs, so that I could hear what the difference between plans was. This might have been a bit ambitious (and wasteful), but I always built the T30s knowing that I'd be building a 2nd rig somewhere down the line. The original plan was actually for 3 rigs :o #1=T30+OT12 (small portable rig - DONE); #2=T48+DR250 (loud rig); #3=T60+DR280 or 300 (club install type rig). Rigs #2&3 have now been combined into the T48 or T60 and DR250s (I can always add in the larger DRs later on - I will build some 300s one day ;) ). The reason why I wanted to build the T48 was to find out how loud those are and I didn't need a reason for the T60... it was that T60 video from Infracousic that first made me type 'Bill Fitzmaurice' into google all those months ago ;)
Then about a two weeks ago, I was looking at SPL charts and realizing that the T48 would actually be louder than the T60s. I therefore started to question whether I actually needed that extension. This had nothing to do with what I heard on the night... it was just a trick of timing that I was contemplating T48s whilst commenting on my T30s first performance here. Getting rig #1 out meant that it was working, completed, done. My thoughts therefore have turned to considering my next move (actually they've already done that - DR250s are next, but I'm thinking several moves ahead like a chess player!)
chrisj360 wrote:I am curious mainly because even though I am super stoked on how my 28" tuba's came out and sound, I keep wondering if I should have built the titans instead. I've been having an internal debate for awhile now (see http://billfitzmaurice.info/forum/viewt ... =1&t=21441 ) about either ordering the titan plans and building a pair or just building another pair of tubas.
I'm with you on that one... I'm having the exact same mental discussion!
chrisj360 wrote:I love how clean and low the tubas go and initially I wanted to go for clean full bass, rather than just loud. But I've been to a few other shows recently where it just seems like the audience wants stupid loud, regardless of the hearing damage they are being subjected to.
And that's EXACTLY the reason why I was thinking T48! The audience cares for loud far more than it does for extension. We're on the same page here (in fact we're probably on the same letter of the same sentence of the same paragraph).
chrisj360 wrote:My intentions aren't to hijack the thread...
Don't worry, I think it had died anyway - you've brought it back to life!
chrisj360 wrote:...or start another tuba vs titan debate. I would just really appreciate some input from another fellow tuba builder (non-T60 because it's not fair to compare the T30 to a T60). I know that don and a few other tuba builders are still super happy with their systems, as I am but it seems that we both dj more similar music. But with the ratio of titan to tuba builders (once again non T60), I am curious if I should have built the titans.
I know that everyone just says that if you are playing dance music you should use Tubas - and if you want it louder, just build twice as many... but doubling up 4 subs to 8 means a LOT of packspace... if I was to build 4 Titans instead, it would still be the same amount of work (4 subs), but I wouldn't need a lorry to move them! In your case you could build 2 Tubas, or get the same output by building 2 Titans - either way it's 2 cabs to build but if you wanted to extend it after that, it would be a whole lot easier building another 2 Titans (if you went that route), than another 4 Tubas. And the difference between T30 and T48 extension is only 5Hz... that's not a massive amount of bass to lose.
I have no answers, only my musings which I have put down here so that we can compare notes (and maybe get some input from others). Either way, I'm sure that you will be happy with the result, but I'd love to have the 3 subs that I have mentioned in this thread to audition and actually hear the difference, rather than trying to extrapolate out what they sound like from their SPL charts.
chrisj360 wrote:One thought though, when I was building my tubas I had some issues with rubbing on the baffle that lead me to repeatedly removing the driver, sanding, remounting, checking and then starting the process over again. After some time, a number of the holes for driver recex screws became stripped out so be careful with how many times you would potentially swap out your drivers between the different cabinets. I don't know if it was just user error on my part but wanted to share my experience.
My tee-nuts are mounted solidly... I made sure of this and took extra time to get it right, as I was assuming even at that early stage that I would be removing drivers and swapping them between cabs.
chrisj360 wrote:I very much remember that game you based your handle on. My favorite was pitfall and qbert as a kid.
Qbert... yeah! :) Who knew he'd grow up to become such a great scratch DJ. I guess it was those whirly disks that took you back to the top that got him interested!
chrisj360 wrote:Sorry for the long winded post, I didn't mean for it get this big.
We're cut from the same cloth, methinks... I start with my post just wanting to make a simple point, but by the time I hit 'Submit', it has turned into a novel (see this post for an example!). Please don't apologize, long posts are good and keeps me (and others :fingers: ) entertained for longer whilst skiving off work.
escapemcp
#23 Post by escapemcp »
Grant Bunter wrote:Sorry for the sidestep...
Don't be... it all helps build knowledge. :)
Jools4001
#24 Post by Jools4001 »
I don't inhabit the same world from a musical point of view. Crusty old rockers and DJs are poles apart, and I don't even understand the different genres you're talking about - dubstep, quickstep....whatever.
But great sound quality is great sound quality, regardless - and I do understand that, so kudos on putting a cool system together.
2 x 3012 HO Jack 12 Lites
Subs? Big question mark!
Faux127
#25 Post by Faux127 »
escapemcp wrote: And the difference between T30 and T48 extension is only 5Hz... that's not a massive amount of bass to lose.
From 30-35hz it's not, but from 35-40hz you're losing a LOT of the main sub frequencies used in dubstep. I would not be satisfied with the extension of less than 4 titans.
sine143
#26 Post by sine143 »
in my experience, VERY few dubstep tracks (particularly brostep) or drum n bass tracks dip below about 37 EVER or Often (maybe 1 or 2 sweeps per track).
That being said ALMOST ALL tracks have heavy content between 40 and 50, and many of them have heavy content above that.
Yes, 2 t30s will sound good on dubstep that dips to 35. and 2 t48s will sound almost like 4 t30s on every other track.
Faux127
#27 Post by Faux127 »
To each his own, but keep in mind it's already -3db down at 40hz with <4 titans :fruit:
88h88
#28 Post by 88h88 »
sine143 wrote:in my experience, VERY few dubstep tracks (particularly brostep) or drum n bass tracks dip below about 37 EVER or Often (maybe 1 or 2 sweeps per track).
Even UK basslord Reso said his tracks rarely dip that low, he posted up an old track a couple of weeks ago where he said:
Faux127
#29 Post by Faux127 »
Sample song, I've analyzed a lot of songs I would play, most being from 37 to 45 hz
edit: forgot to name it, this is "Noisia - Diplodocus (Kill the Noise remix)"
http://s21.postimg.org/wkb6dc9bb/Untitled.png
escapemcp
#30 Post by escapemcp »
Jools4001 wrote:I don't inhabit the same world from a musical point of view. Crusty old rockers and DJs are poles apart, and I don't even understand the different genres you're talking about - dubstep, quickstep....whatever.
I have no idea what quickstep is either! It's mainly psytrance that gets played on the rig
Jools4001 wrote:But great sound quality is great sound quality, regardless - and I do understand that, so kudos on putting a cool system together.
TYVM
Faux127 wrote:From 30-35hz it's not, but from 35-40hz you're losing a LOT of the main sub frequencies used in dubstep. I would not be satisfied with the extension of less than 4 titans.
I was going to build 4 if I went the titan route, which I am thinking still plays lower than most other rigs - this is why I am thinking that the extra volume of a T48 setup will be noticed more than the extension of my T30s.
Brostep :confused:
sine143 wrote:That being said ALMOST ALL tracks have heavy content between 40 and 50, and many of them have heavy content above that.
So 4 T48's will sound like 8 T30s most (99%) of the time.. this is exactly the problem (although it's a nice one to have :)
On a totally unrelated note, just received my new solder station from eBay - chinese special (they hadn't even bothered to translate the manual at all this time round!!) http://www.ebay.co.uk/itm/291045808706:
Very impresssed with it. The tip heats up in about 20 seconds compared to the 5 minute warm up of my basic iron. I was out tonight as it is my birthday, but couldn't wait to get back and have a play with it. I'm really looking forward to my weekend solder session now :) And all that for just £26 - that's only a few quid more than my basic iron I was using previously :hyper:
Sorry for hijacking my own thread... I just had to post as I was so happy with my new soldering setup :slap:
