I did a naughty thing. Moxie with 4xOT12s, 2xT39s and 2xT60s
88h88
Re: I did a naughty thing. Moxie with 4xOT12s, 2xT39s and 2x
#16 Post by 88h88 »
What's in your rack? ...and can you run an XLR to somewhere else in the room?
osse
#17 Post by osse »
I have nothing to measure spl for the moment, the best would be a stand alone unit with a big illuminated display to put beside the dj table. And yes I can use 20 meter of cable if it would give me a good viewpoint of spl on the dancefloor! One of the most unprofessional club environments is one which don't have controll over their levels! But a rack unit would be fine if there are no standalone ones. What rack unit is it u have that reads db?
88h88
#18 Post by 88h88 »
The Behringer DEQ has an SPL meter display but that's no good to you unless you can point it at someone's eyes.
#19 Post by AntonZ »
Disco-inferno wrote:I found a lumber yard that has decent ply at under 25 euro's per sheet roughcut
Wow. That's almost worth driving up and down to Tilburg for :shock:
Disco-inferno
#20 Post by Disco-inferno »
it's a lumber yard in gemert Anton, there's another one in boven leeuwen, they have a net price of €16,20 per 4 by 8 sheet. but then I have to wait until someone wants the rest of the pallet.
plus they don't want to quote a price for cutting up the sheets.
Mark Coward
#21 Post by Mark Coward »
88H88, what are you running for crossover? Did you cross between the subs? If you have the DCX, it can do 2 x 3way - or my preference is using an Aux sub send, since it has a 3rd input as well. I've experimented with splitting between tubas and titans from 60hz - 80hz, and around 120hz to OT's.
Mark Coward
88h88
#22 Post by 88h88 »
Mark Coward wrote:88H88, what are you running for crossover? Did you cross between the subs? If you have the DCX, it can do 2 x 3way - or my preference is using an Aux sub send, since it has a 3rd input as well. I've experimented with splitting between tubas and titans from 60hz - 80hz, and around 120hz to OT's.
I have a DCX2496 handling the crossover/limiting. I had the T60s running 25hz-60 and the T39s 60hz-100 and the OTs from there upwards. Both subs were on a 48db/octave filter where they met.
I still need to fiddle with the setup as it sounded pretty damn fine but I reckon with some tweaking it could be improved.
Bas Gooiker
#23 Post by Bas Gooiker »
Disco-inferno wrote:it's a lumber yard in gemert Anton, there's another one in boven leeuwen, they have a net price of €16,20 per 4 by 8 sheet. but then I have to wait until someone wants the rest of the pallet.
Wow those are some great prices, and almost in my backyard. I wish i knew about this before, when i get back from Korea visiting them will be the first thing on my to do list!
What is the name of the place Disco?
