Page 2 of 4
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 2:35 pm
				by sine143
				Its really not THAT spendy... only like 1.5 times the price of normal black paint.
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 3:08 pm
				by TheCesar
				racertomtom wrote: Yes, I put 2 coats on 2-T39s, 2- OT12s and 4 WH8s. I have 1/3 gallon left.
Thank you, so I should have plenty left for future builds, do you thin it at all and did you use a roller or sprayed it on?
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 3:32 pm
				by racertomtom
				TheCesar wrote:racertomtom wrote: Yes, I put 2 coats on 2-T39s, 2- OT12s and 4 WH8s. I have 1/3 gallon left.
I rolled it on without thinning.
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 3:45 pm
				by TheCesar
				racertomtom wrote:TheCesar wrote:racertomtom wrote: Yes, I put 2 coats on 2-T39s, 2- OT12s and 4 WH8s. I have 1/3 gallon left.
Thank you!
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 3:47 pm
				by TheCesar
				sine143 wrote:Its really not THAT spendy... only like 1.5 times the price of normal black paint.
For some reason in mi mind even paint is spendy,
 Last time my wife made me paint the house it was sad to see the cash I needed to spend on that.
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 3:57 pm
				by sine143
				well.. tbh I'm in the same boat... but somethings gotta go on there... and if I compare it to what I would spend on flat black... it makes me feel less
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 4:28 pm
				by TheCesar
				sine143 wrote:well.. tbh I'm in the same boat... but somethings gotta go on there... and if I compare it to what I would spend on flat black... it makes me feel less
True, unless, you paint it with cheap .99 black spray can paint
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 9:26 pm
				by TheCesar
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 9:34 pm
				by Grant Bunter
				Fill it up/rebuild the thickness with succesive applications of bondo if you think that will suffice, or  add a nice thin piece of ply and PL it on, let it set, and re trim...
				Re: W10 in progress
				Posted: Tue Aug 06, 2013 10:43 pm
				by TheCesar
				Bondo should work after fiting it in its not to bad, my only concern with bondo is what ive read about duratex. Thanks for your quick reply grant!
				Re: W10 in progress
				Posted: Wed Aug 07, 2013 7:15 am
				by Scott Brochu
				an 1/8" is not bad when you are cutting the horn to fit inside the cabinet box.
When you install the horn inside the box put a large bead of PL on that side.
				Re: W10 in progress
				Posted: Wed Aug 07, 2013 7:33 am
				Scott Brochu wrote:an 1/8" is not bad when you are cutting the horn to fit inside the cabinet box.
+1, especially if you use some temporary screws to hold the horn in place with the gap halved to either edge.
				Re: W10 in progress
				Posted: Wed Aug 07, 2013 11:10 am
				by TheCesar
				Bill Fitzmaurice wrote:Scott Brochu wrote:an 1/8" is not bad when you are cutting the horn to fit inside the cabinet box.
Thank you, I was really mad at my self for making this stupid mistake, this takes some stress out of my life.
I was sure that I would find a solution here on the forum.
Again Thanks to all of you for your help!
				Re: W10 in progress
				Posted: Fri Aug 09, 2013 4:07 pm
				by TheCesar
				Hello guys,
I have a quick question ive read the plans several times but im not sure if im just missing it or it does not have it in there, i need the steps to break the speakers, i was wondering if there is a tread already about it or a link that can walk me on how to break them.
				Re: W10 in progress
				Posted: Fri Aug 09, 2013 11:28 pm
