First Omni 15 Full Range build...
All Thumbs
Re: First Omni 15 Full Range build...
#16 Post by All Thumbs »
Sexy metal Bill Fitzmaurice badges arrived direct from the States thanks to http://www.speakerhardware.com/ :-)
First time builder of 2 x Omni 15 Full Range - wish me luck :-)
Scott Whitley Bass Guitar Services
Web: http://www.scott-whitley.com
Facebook: http://www.facebook.com/scott.whitley.bass.services
All Thumbs
#17 Post by All Thumbs »
So that's everything up to date.
Today looks like a nice sunny day here in the UK so I'm seriously hoping to get one cab to near completion today!!!
Will post progress pic's later....
All Thumbs
#18 Post by All Thumbs »
Really, really, really p*ssed off!!!!!
Just went out to leisurely trim the horns to size as described in Bill's plans only completely wreck the past two days work!!!!!
With each cut things got steadily worse. Nightmare :wall: :cussing:
All Thumbs
#19 Post by All Thumbs »
Oh well, nobody died I guess!
Time to make another two :-(
#20 Post by Chris_Allen »
Using lesser grade ply on internal components is fine - the big advantage to birch is that it resists dents far better due to it's strength. On the mid horn, that's not applicable, though, birch is much nicer to work with.
When trimming the tops of the horn, I would build a small 'L' shaped sled to put it on so your edge with your fence is straight.
#21 Post by LelandCrooks »
Happens to the best of us on the throats. Saw sled, go very slowly.
All Thumbs
#22 Post by All Thumbs »
LelandCrooks wrote:Happens to the best of us on the throats. Saw sled, go very slowly.
Yeah cheers for the advice - just making a sled now. Thought going up against the table saw fence would have sufficed but obviously not lol!
All Thumbs
#23 Post by All Thumbs »
Chris_Allen wrote:Using lesser grade ply on internal components is fine - the big advantage to birch is that it resists dents far better due to it's strength. On the mid horn, that's not applicable, though, birch is much nicer to work with.
Thanks for the tip Chris!
All Thumbs
#24 Post by All Thumbs »
So I made a sled/jig....
All Thumbs
#25 Post by All Thumbs »
Parts cut AGAIN for a new pair of horns to replace the ones I trashed this morning lol...
All Thumbs
#26 Post by All Thumbs »
And here are the finished replacement horns. I shall very carefully trim them in the morning using the sled/jig I made today. Wish me luck...
#27 Post by AntonZ »
All Thumbs wrote:So I made a sled/jig....
You are going to love that jig. Makes trimming of the horns so easy.
I built a WedgeHorn some time ago, which has a similar shaped but larger horn that needs to be trimmed down to fit the shell. Super tight fit, and it was dead easy.
Making great progress there Scott. I'm looking forward to you using the pair at full blast first time. Be sure to have some hearing protection. Structural damage to your house may occur :cowboy:
All Thumbs
#28 Post by All Thumbs »
AntonZ wrote:I'm looking forward to you using the pair at full blast first time. Be sure to have some hearing protection. Structural damage to your house may occur :cowboy:
Love it :-)
All Thumbs
#29 Post by All Thumbs »
Excellent!!!! The jig/sled made the job 1000% easier :-)
#30 Post by AntonZ »
They do indeed look quite a bit better than the first pair. Well done :clap:
