What counts is how it works. in most cases all you get with 12ga speaker cable is extra bulk and weight, while not working the slightest bit better. As for 10ga extension cords they only make sense if the AC wiring they plug into is also 10ga. And unless it's a 30 amp circuit, using 30 amp rated outlets, it isn't.DJPhatman wrote: +1 I prefer 12 gauge for speaker wire. I used 10 gauge for my extension cords.
Speaker Wire
Re: Speaker Wire
Re: Speaker Wire
Bill Fitzmaurice wrote:What counts is how it works. in most cases all you get with 12ga speaker cable is extra bulk and weight, while not working the slightest bit better. As for 10ga extension cords they only make sense if the AC wiring they plug into is also 10ga. And unless it's a 30 amp circuit, using 30 amp rated outlets, it isn't.DJPhatman wrote: +1 I prefer 12 gauge for speaker wire. I used 10 gauge for my extension cords.
Bill! Quit confusing the issue with facts!
We used to play a place where the whole band had four outlets.....the wires running to all four (ganged together) looked to be no bigger than 16ga. Can't believe it never melted down.
- BrentEvans
Re: Speaker Wire
While this is true in most instances... suppose you run into a situation where you have to couple two or three regular speaker cables together to make a run? Not every situation is optimal... having 12 gauge cables would be a benefit then.Bill Fitzmaurice wrote:What counts is how it works. in most cases all you get with 12ga speaker cable is extra bulk and weight, while not working the slightest bit better.
FTR... my FOH cables are all 13/4 becasue at most of my events, I have to place the amp rack 75 feet or more from at least one stack. Having the 13/4 was a big benefit to me.
No. 10 extension cables also have less voltage drop in less than optimal situations...As for 10ga extension cords they only make sense if the AC wiring they plug into is also 10ga. And unless it's a 30 amp circuit, using 30 amp rated outlets, it isn't.
There's nothing wrong with a little overkill 75% of the time to have what you need 25% of the time.
Re: Speaker Wire
If the cables are that long the capacitive and inductive losses will be the main concern, and gauge does nothing to address that.BrentEvans wrote: While this is true in most instances... suppose you run into a situation where you have to couple two or three regular speaker cables together to make a run? Not every situation is optimal... having 12 gauge cables would be a benefit then.
At 100 feet the difference between 10 and 12ga is 1 volt.No. 10 extension cables also have less voltage drop in less than optimal situations...
- BrentEvans
Re: Speaker Wire
And at 200ft and 15-20A it's 4-6v... and that type of cable run does happen in less than optimal situations. Further... peak power usage on a single circuit (like kick drum hits) can drive it farther than that.Bill Fitzmaurice wrote:If the cables are that long the capacitive and inductive losses will be the main concern, and gauge does nothing to address that.No... but
Some equipment, particularly class D amps and certain digital processing gear, shut down even on minor dips in voltage. Not every event has the luxury of a distro, or even multiple circuits to drive your gear. What's the harm in making sure you're prepared as much as possible?
Re: Speaker Wire
My mistake it is a speaker cable. I don't think anyone makes a 12 gauge instrument cable. lol
I have them cut at about 25ft a piece.
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Re: Speaker Wire
In most situations where that amount of wire is required it's an outdoor gig, and you run a high risk of getting shocked, or worse, being that far from the service ground. Not recommended practice, to say the least. I've had it happen to me before I knew better; it will never happen again.BrentEvans wrote: And at 200ft and 15-20A it's 4-6v... and that type of cable run does happen in less than optimal situations.
None, but that means not endangering yourself because some idiot thinks you can set up your gear anywhere.What's the harm in making sure you're prepared as much as possible?
- BrentEvans
Re: Speaker Wire
Or running around baseboards from one room to another trying to find an unoccupied circuit. Point is, it happens.Bill Fitzmaurice wrote:In most situations where that amount of wire is required it's an outdoor gig, and you run a high risk of getting shocked, or worse, being that far from the service ground. Not recommended practice, to say the least. I've had it happen to me before I knew better; it will never happen again.
With great power comes great responsibility. I've done some pretty shaky extension cord runs in the past too, but I can't any more. My amps and processing gear don't like low voltage (as in, will shut down at 102 volts). It's actually a great excuse to make people provide the right power... if I can't power up, they can't go on.None, but that means not endangering yourself because some idiot thinks you can set up your gear anywhere.
Re: Speaker Wire
Showing my age here... I remember back in the 70's and 80's the argument was trying to get people to stop using 18ga. for long runs- 16ga. was the way to go.
Re: Speaker Wire
That was before the advent of the cable mountebanks and the nonsense that they promulgate. But I was using 14ga in the 70s and 80s, as I do today. Mostly the same wire too, with the original 1/4" plugs replaced by Speakon.Rick Lee wrote:Showing my age here... I remember back in the 70's and 80's the argument was trying to get people to stop using 18ga. for long runs- 16ga. was the way to go.
Re: Speaker Wire
AWG 16 is fine for Home Hifi, but with pro audio, AWG 14 is better due to the longer runs involved. With smaller wire gauges, the power loss goes up, but more importantly, damping factor is the first thing to be degraded significantly as the wire resistance is increased.
If you have runs with distances longer than what is acceptable for a #14, it's time to relocate the amplifiers racks and run a longer line level feed instead.
T48s
WH8s
SX212
T48s
WH8s
SX212
- Harley
Re: Speaker Wire
Good grief FitzYoda! Converted over to Monster, have done you not yet?Bill Fitzmaurice wrote:.... But I was using 14ga in the 70s and 80s, as I do today. Mostly the same wire too, with the original 1/4" plugs replaced by Speakon.
Re: Speaker Wire
On the topic of cabling. Here's an interview from yesterday with Monster Cable founder. He talk about the technical side of things. (I'm sure much of his claims are bunk).
http://www.podtrac.com/pts/redirect.mp3 ... tg0131.mp3
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
SLA Pro x 2
Yamaha S112V x 1
QSC RMX 2450
dbx Driverack PA
Re: Speaker Wire
They're all bunk. If Monster and all the other cable crooks had to prove all their claims they'd go out of business in a week. This is the real deal where cables are concerned:Dan30 wrote:On the topic of cabling. Here's an interview from yesterday with Monster Cable founder. He talk about the technical side of things. (I'm sure much of his claims are bunk).
http://www.roger-russell.com/wire/wire.htm
