Which 10" for a bass quad box?
Re: Which 10" for a bass quad box?
#16 Post by Grant Bunter »
G'day Greg,
Best place to buy some of the eminence product line locally is essential audio.
Here's a link to BP102's from them...
http://www.essentialaudio.com.au/conten ... eaker.html
SirNickity
#17 Post by SirNickity »
Bill Fitzmaurice wrote:
SirNickity wrote: BP102 would work.
There's a reason why we only use BP102s as subs in our cabs. It's clearly seen on the manufacturer data sheet.
Are you referring to the nose-dive at 2kHz? I'll agree it's certainly not full-range by any stretch, but I don't know that it rules it out of the running. If you use a tweeter (or specifically don't use a tweeter for the so called "vintage" sound), it may even work out in favor.
Disagree? Or is it something that I don't get? You're being cryptic again. :wink: Use your words!
#18 Post by Bill Fitzmaurice »
That and the trough from 300 to 900Hz, which kills the mids.
1n3
#19 Post by 1n3 »
Bill Fitzmaurice wrote:That and the trough from 300 to 900Hz, which kills the mids.
Yup. And by coincidence, that's about where the J10 horn produces a big response hump. At first glance, it would seem like a good (complimentary) combination, but you have said the BP102 is not suitable for the J10. Can you elaborate?
To get back on topic, I agree with previous postings re: 410s. They're widely available for less than build-cost, and the design is flawed. Don't see a good reason to build one unless you want the speakers in a vertical rather than square array.
