Page 2 of 2
Re: DIY stage
Posted: Wed May 30, 2012 4:31 pm
by James R
Outdoor carpet, or something with traction
Re: DIY stage
Posted: Wed May 30, 2012 5:10 pm
James R wrote:Outdoor carpet, or something with traction
+1
Re: DIY stage
Posted: Fri Jun 01, 2012 10:55 am
by mattaudio
I was at HD last night picking up sheetrock and other paneling. 7/16 OSB sure is cheap, even compared to underlayment. Maybe it would work for 4x8 stage panels with studs underneath at 16" or maybe 12" on center.
Re: DIY stage
Posted: Mon Jun 04, 2012 10:24 am
by gdougherty
mattaudio wrote:I was at HD last night picking up sheetrock and other paneling. 7/16 OSB sure is cheap, even compared to underlayment. Maybe it would work for 4x8 stage panels with studs underneath at 16" or maybe 12" on center.
The stage I described was built out of OSB.
Re: DIY stage
Posted: Mon Jun 04, 2012 5:15 pm
by sine143
OSB plus Shipping pallets (find at the back of your least favorite supermarket). + a ton of cinderblocks.
Re: DIY stage
Posted: Tue Jun 05, 2012 10:20 am
by mattaudio
What's the advantage of using pallets underneath instead of a 2x4 frame? Easier to build?
Re: DIY stage
Posted: Tue Jun 05, 2012 5:46 pm
by guitarkeys.com
Matt,
Drop me a PM and I can send you some plans for a portable stage. I did 3 x 6 panels as that is a good size for a one man setup. Stage height is up to you. I have 18", 32", and 48" heights and all have been extremely solid.
Re: DIY stage
Posted: Tue Jun 05, 2012 5:48 pm
by sine143
mattaudio wrote:What's the advantage of using pallets underneath instead of a 2x4 frame? Easier to build?
cost effectivness, ease of breakdown (burn it etc). allows you to make 1 time stages without worrying about hauling or purchasing materials.
