Dubwoofer's Tuba HT build
subharmonic
Re: Dubwoofer's Tuba HT build
#16 Post by subharmonic »
Use a light to look for leaks.
I need more bass
CW Mcall
#17 Post by Tom Smit »
subharmonic wrote:Use a light to look for leaks.
Soooo true!
Dubwoofer
#18 Post by Dubwoofer »
88h88
#19 Post by 88h88 »
Haha I think I have a picture of similar. We just grabbed everything in the garage and piled it on top. You have to be sure it's being compressed. :D
Dubwoofer
#20 Post by Dubwoofer »
All done. I put about a hundred brad nails in each side to reinforce things.
:horse:
Dubwoofer
#21 Post by Dubwoofer »
Uhhh...
Alrighty... It engulfed my garage in a 30Hz tone that shook the doors, walls and lights all while sitting on the saw horses in the center of the floor. That's just ridiculous.
bassmonster
#22 Post by bassmonster »
This has got to be the cleanest THT build I've seen here, it's just beautiful. :clap: :clap: :clap:
From the description it sounds like you don't have any leaks, but I'd still check around the driver to make sure. Aquarium air hose makes a great "stethoscope" to listen for leaks, play a 20hz tone and the tone will be inaudible but you will be able to hear the air rushing out of the leak.
Are you going to finish it? I'd go as far to say it probably wouldn't need much finishing to be WAF approved, it just looks that good. Great work!
88h88
#23 Post by 88h88 »
If it sounds as good as it looks then you're all good. :shock:
#24 Post by Radian »
:clap: Nice looking cab. Very clean!
fitzwaddle
#25 Post by fitzwaddle »
Looks very nice, congrats. Curious though - that's the first time I've seen a plate amp mounted into the chamber cover - is there any concern that the backwave could stress the plate amp? I guess it could be boxed in if that was truly an issue, but then it would reduce the volume of the chamber?
Drey Chennells
#26 Post by Drey Chennells »
fitzwaddle wrote:Looks very nice, congrats. Curious though - that's the first time I've seen a plate amp mounted into the chamber cover - is there any concern that the backwave could stress the plate amp? I guess it could be boxed in if that was truly an issue, but then it would reduce the volume of the chamber?
Unlikely the plate amp is airtight..
InfraCoustik
Consulting/Design/Fabrication
Authorized BF Builder
http://www.infracoustik.com/
info@infracoustik.com
Dubwoofer
#27 Post by Dubwoofer »
It wasn't at first.. The only leak was from a small gap in the amp's gasket which I filled with a dab of sealant. After that I could not detect any leaks in the box or around the driver
Dubwoofer
#28 Post by Dubwoofer »
After moving it into the home theater... It's good I'm a bachelor.
So far no problems at all with the amp mounted on the access cover.
I'll need to do something about the rattling movie posters and lights
Drey Chennells
#29 Post by Drey Chennells »
That's good Dub but be sure to carefully check the rca jacks and highlevel speaker inputs, etc. as they are usually leaky. That chamber has to be 100%. :wink:
InfraCoustik
Dubwoofer
#30 Post by Dubwoofer »
Yep, everything on the amp was sealed with GOBS of goo and and I can't find any leaks using the stethoscope tube method.
