2 Jack 112s
Re: 2 Jack 112s
I used similar stuff (though less bubbly it appears) for subs and made double-triple sure everything was airtight before putting the side on. This process involved running over joints 2-3 times more until we were happy it was all sealed. The cab is more adhesive than wood and that's purely because I didn't trust the adhesive enough. It can be done but it's too much of a complete ballache and if you screw up then you've screwed up bigtime as once that last side is on it won't come off easily.
- Harley
Re: 2 Jack 112s
The problem with stuff like this http://www.titebond.com/ProductLineTB.a ... prodline=6 is that it's like treacle and easily dribbles away from the joint if the surface is not completely level. Like PL, it relies on compression and moisture for cure, but even with compression it can still seep away from the joint.
That's why a gelled 100% exp polyurethane ( in a tube ) works better. It stays there.
A couple of years ago I did extensive experiments with all sorts of glues and spoke with the rocket scientists that produced the stuff. The titebond is actually as strong as the gelled polyurethane BUT under the right application conditions and cabs are NOT the right application conditions.
In fact talking of glue strengths, I had a hot melt glue that was quickly clamped under intense pressure and let settle for 24 hrs yield as much tear strength on the ply joints as PL BUT, again, it's totally impractical for cab building.
Re: 2 Jack 112s
As I said, too late. I've used this on my 2 Jack 12s.
Re: 2 Jack 112s
Unfortunately, PL is not available in the UK and at $30 or more a tube to ship, it's a bit expensive to ship here.
Re: 2 Jack 112s
If Two Tone had put his location in his name info - he might have gotten a better response that would be applicable to his situation. There a lot of builders in the UK that probably would have chimed in with suggestions.tcorder wrote:Unfortunately, PL is not available in the UK and at $30 or more a tube to ship, it's a bit expensive to ship here.
Bill, you should make location a required field in the setup for the forum. It would save a lot of unnecessary keystrokes and misunderstandings.
Re: 2 Jack 112s
The software decides that, not me. It's up to the user to put in their profile their location so we know, or leave it out and let us ask 30 questions to figure it out.Bruce Weldy wrote: Bill, you should make location a required field in the setup for the forum. It would save a lot of unnecessary keystrokes and misunderstandings.
Re: 2 Jack 112s
I really appreciate all the help guys. I'm actually from Australia and did some research to try to find PL before I started but couldn't.
So my plan of attack now is to get the back on, run a tone through them and see how I'm doing for leaks. All my joints were pretty much spot on with no gaps so I'm hopeful. If they do whistle and leak I'm thinking I'll attack it on the inside with some sikaflex or similar heavy duty sealant around the joints. If that's no dice then I guess I just have to start again
lincsoldbird
Re: 2 Jack 112s
Try toolstation.com Lumberjack 5 min pu in a tube about £6.tcorder wrote:Unfortunately, PL is not available in the UK and at $30 or more a tube to ship, it's a bit expensive to ship here.
built 4 T30 24in BP102 now sold 2 DR280
2 speakerplans 1850, 2 MT102 ,2 X15, 1 G sub now sold
2 T60,s Built plus 4 DR280,s in the build
Re: 2 Jack 112s
This is the stuff we used on ours, it works really really well but we used multiple applications on the panels and then pretty much drowned the edges before putting the final side on and weighting it for 12 hours.lincsoldbird wrote:Try toolstation.com Lumberjack 5 min pu in a tube about £6.tcorder wrote:Unfortunately, PL is not available in the UK and at $30 or more a tube to ship, it's a bit expensive to ship here.
Re: 2 Jack 112s
Ok, so after a brief hiatus where I was so peeved with myself for using the wrong glue, I'm back into it. I've sealed the joints that I can reach with a polyurethane flexible filler and added my drivers and back panel. One of the cabs is all good, no leaks apart from a small leak where I've mounted the connector tray on the rear panel, which I haven't siliconed yet. The other one is not right, there's a popping noise coming from it when I turn up my test signal (30 Hz) to a reasonable level. If I run the test signal at 50 or 80 Hz then the noise does not become apparent until higher levels.
I remembered reading this post http://billfitzmaurice.info/forum/viewt ... ug#p151568 about a similar problem so pulled the driver, but the dust cap looks fine, no dents or marks where it might have been hitting. At the levels I tried it at I could hear no leaks (using the flexible hose as stethoscope method).
I'm about to go away for the week for work, but hoped maybe some people might have some suggestions for me. Should I try swapping the drivers in the two cabinets? They are both brand new Deltalite 2512s. Could it be that a leak in the dodgy one is cause the driver? The same signal was run into the two drivers giving the two different results.
I'm feeling pretty good about the whole glue issue and the predicted leaks have not eventuated. All my panels were cut true and exact so I think that's helped a lot. I just need to get to the bottom of this problem now, can't wait to try these cabs at rehearsals and gigs.
I've included some pics for interest, one where you can see the sealant I've used.
thanks for all the comments everyone.
Re: 2 Jack 112s
I just bought 2 tubes of the 30min lumberjack gel, I hope I chose well because gripfill didnt work out so well last time88h88 wrote:This is the stuff we used on ours, it works really really well but we used multiple applications on the panels and then pretty much drowned the edges before putting the final side on and weighting it for 12 hours.lincsoldbird wrote:Try toolstation.com Lumberjack 5 min pu in a tube about £6.tcorder wrote:Unfortunately, PL is not available in the UK and at $30 or more a tube to ship, it's a bit expensive to ship here.
To do:
To do:
- Dave Non-Zero
Re: 2 Jack 112s
I've just used the B&Q PU glue for all my cabs,
http://m.diy.com/mt/www.diy.com/diy/jsp ... t_redirect
I couldprobably get cheaper stuff online, but I always need 'one more tube' in the middle of a project.
Not had a leak yet....
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Re: 2 Jack 112s
Re: 2 Jack 112s
That usually indicates the driver exceeding xmax, usually the result of a leak. But be very aware of what a 'reasonable level' is at 30Hz. J112 will reach xmax at 30Hz with 16v input. Output will be around 100dB, but 100dB at 30Hz isn't as loud as you'd think, being only as audible as 70dB at 200Hz.TwoTone wrote:there's a popping noise coming from it when I turn up my test signal (30 Hz) to a reasonable level. If I run the test signal at 50 or 80 Hz then the noise does not become apparent until higher levels.
- Chris_Allen
Re: 2 Jack 112s
Is that the old Fletcher-Munsen [sic?] curve?Bill Fitzmaurice wrote:but 100dB at 30Hz isn't as loud as you'd think, being only as audible as 70dB at 200Hz.
