I added the Foam, (Mattress Top Foam from Fred Meyers ). I fit each Horn to each Cabinet, then glued in the braces only to the Cabinet. Then I added foam to the inside of the cabinet and then the horn. Try not to add too much foam to the front of the Cabinet area, about 2" away from the mouth and for the horn about 4" away from the front.
Make sure to dry fit the horn to the cabinet before adding PL. I then glued the Horn to the Cabinet. This is all being done without the Speaker Baffle attached. Added a single #18 brad into each Brace to hold while drying.
For the foam, I used 3M Super 77. Works fast, just spray the foam, then add to the Horn or Cabinet.
Below, the area to the left, inside the cabinet, is where I will mount the XO.
For the Baffles, I used the Plastic Pet Screen. Easy to work with. I PL'ed the screen to the Speaker side of the Baffle. Let that dry over night, then added the Throat Fillers. Very easy to work with, just 3/4" Insulation, cut to size, then sand the angle. Cut into pieces, then added to the Baffle. After it all dried, I trimmed the Screen around the Filler. Then just PL the Baffle to the Horn.
I added a few inserts on the Baffle, towards the inside of the cabinet. Its makes it easier to mount the speaker, there is not much room in there. I used Allen Head Bolts for these 2 inserts, then I will use #8 Pan Head 1 1/2" Wood Screws to secure the speaker.
