Gauss wrote:I also used hot glue to put in the diffuser. It was an easy way to make sure that it followed the slight bend of the piezo array. I kept trying to figure out how to clamp it down while the glue dried. I figured that since I used hot glue to put the crossover in place, it would be strong enough for a light dowel (behind a grill). Plus, when I moved the coil in my crossover, it worked so well that I took up a layer of ply with the glue.
I'd be worried about how regular hot glue would hold up on plastic in the long haul. If it comes off at a gig, no biggie, we've been running without them for how many years now? If you can scuff up where it glues with some 40 grit, it'll hold better.
Robby
