Cjeff wrote: That is what a guy who was here who is a DJ said. (Son of a regular attender, who was visiting.)
Listening with his eyes. Piezos.
No they both would have definitely been in the coverage.Radian wrote:Are they pointed directly-at-the-listeners in the vertical plane? A laser pointer taped along the edge of a combination or try square, then swept from side to side will give you a visual idea of the spread those arrays. They could've been off-axis and out of the zone.Cjeff wrote: Many liked the sound, A couple said they sounded 'Hollow" or "tinnie" Maybe I need to break them in more?
We EQ'd them using the feedback procedure as outlined here.Bill Fitzmaurice wrote:Have they been RTA/EQ'd for the room? If so what some may call 'tinny' is highs that they never heard before.Cjeff wrote:Used them today for the first time.
Overall very good comments. Many liked the sound, A couple said they sounded 'Hollow" or "tinnie"
LelandCrooks wrote:Cjeff wrote: That is what a guy who was here who is a DJ said. (Son of a regular attender, who was visiting.)
Do not use that procedure. It does nothing to actually adjust the system response to the room. It does set response to control feedback, but that's not the same thing. That sort of adjustment is OK with monitors, where maximum levels are desired and quality of response is secondary, but not mains.Cjeff wrote:
http://www.jdbsound.com/art/art537.html
That's the way I learned and still the way I do it more often than not, because situations don't afford the opportunity to do testing.If not, play some music through it and tune it by ear.
My approach as well - 100% by ear. If you're not used to EQing, it may be hard to get the exact sound your after. A good method for training your ear is to pick a band on the EQ, push it all the way up so that you can easily identify the frequency you're adjusting, then pull it all the way down to drop it out, and then slowly bring it back up until it sounds right.Sydney wrote:That's the way I learned and still the way I do it more often than not, because situations don't afford the opportunity to do testing.If not, play some music through it and tune it by ear.
As Klipsch opined " the midrange is where we live" so I work from the center frequencies out, getting that correct first.
Syd
I get that a LOT. Moving the low pass down into the 15-16kHz range to make them sound more like the entry level speakers most are use to normally "fixes" the problem. Then I attempt to educate about what just happened.Bill Fitzmaurice wrote:If so what some may call 'tinny' is highs that they never heard before.
I suppose many have made the same mistake of trusting numbers or a display rather than the ultimate arbiter - the ears.I thought more people would eq by rta'ing.
