Page 2 of 2
Re: Power conditioners
Posted: Mon Jun 07, 2010 10:13 pm
by WB
Monomer wrote:The furman did nothing to save anything plugged in. It is nothing more then a surge strip thats rackmountable.
True, but Furman does make a true voltage regulator that would have saved your gear. I have one, but only bother to use it when the AC is questionable.
http://www.furmansound.com/product.php?id=AR-1215
Posted: Mon Jun 07, 2010 11:04 pm
by subharmonic
Throwing in my 2 cents, my Furman PLX seems to do little to nothing for my Dj rig, however in my home theater the Monster Power 3500 seems to dropped out a lot of noise. Everything seems tighter visually and acoustically with it. Next time I throw in some new gear I will try an A-B test against the Furman.
I have also compared APC S20 and Richard Greys something or other (its been a while) and the APC outperformed it. This was a blind test with a couple of us, it was how the boss decided if we should carry/use gear, vote on what we saw/heard. Pretty fun to play with custom AV stuff for hours on end sometimes.
I believe there is some merit to them, maybe not so much on the pro-audio side since detail is traded for SPL. IMHO
Posted: Tue Jun 08, 2010 7:11 am
by Sydney
subharmonic wrote: however in my home theater the Monster Power 3500 seems to dropped out a lot of noise. Everything seems tighter visually and acoustically with it.
In a home setting you ( usually ) have a much lower noise floor than a live audience.
A big improvement in my home sound was putting my system on a dedicated power line.
There are no other noise sources or anything to affect to mains and it resulted in a noticeable improvement along the lines as you described.
Syd
Posted: Tue Jun 08, 2010 7:51 am
subharmonic wrote:in my home theater the Monster Power 3500 seems to dropped out a lot of noise.
If it did that means that the gear being used is suspect. High quality gear has all the 'conditioning' and noise reduction it needs built in.
Posted: Tue Jun 08, 2010 5:04 pm
by Monomer
WB wrote:Monomer wrote:The furman did nothing to save anything plugged in. It is nothing more then a surge strip thats rackmountable.
If I take a meter to a circuit and the voltage drop dips below 100VAC, I'll pull the plug and leave.
Posted: Tue Jun 08, 2010 5:26 pm
by WB
Good point, but things fluctuate. You won't catch it in time during a gig. Anytime long extension cords or generators are involved I like the peace of mind the voltage regulator provides. In most cases it stays at home.
Posted: Sat Jun 12, 2010 8:37 am
by subharmonic
Bill Fitzmaurice wrote:subharmonic wrote:in my home theater the Monster Power 3500 seems to dropped out a lot of noise.
Not sure what level I need to be at, I use Onkyo 700 series receivers for the last 6 years 701 then a 703 is my current one. I think they sound sweet. Sources were cheapo pioneer, then Onkyo 501? DVD player, then Xbox 360 also. I always thought Onkyo was a good midrange unit.
The gear we tested with the Richard Grey and APC unit was Integra gear (Onkyo's version of Lexus) at the office/shop. Maybe there is an inherent issue with their power supplies that they need a conditioner as all had some degree of improvement.
Too bad I would need to cut a load of plaster to get a dedicated line to my current location, would like to there is a lot of outlets on this circuit.
