Power conditioners
WB
Re: Power conditioners
#16 Post by WB »
Monomer wrote:The furman did nothing to save anything plugged in. It is nothing more then a surge strip thats rackmountable.
True, but Furman does make a true voltage regulator that would have saved your gear. I have one, but only bother to use it when the AC is questionable.
http://www.furmansound.com/product.php?id=AR-1215
subharmonic
#17 Post by subharmonic »
Throwing in my 2 cents, my Furman PLX seems to do little to nothing for my Dj rig, however in my home theater the Monster Power 3500 seems to dropped out a lot of noise. Everything seems tighter visually and acoustically with it. Next time I throw in some new gear I will try an A-B test against the Furman.
I have also compared APC S20 and Richard Greys something or other (its been a while) and the APC outperformed it. This was a blind test with a couple of us, it was how the boss decided if we should carry/use gear, vote on what we saw/heard. Pretty fun to play with custom AV stuff for hours on end sometimes.
I believe there is some merit to them, maybe not so much on the pro-audio side since detail is traded for SPL. IMHO
I need more bass
CW Mcall
Sydney
#18 Post by Sydney »
subharmonic wrote: however in my home theater the Monster Power 3500 seems to dropped out a lot of noise. Everything seems tighter visually and acoustically with it.
In a home setting you ( usually ) have a much lower noise floor than a live audience.
A big improvement in my home sound was putting my system on a dedicated power line.
There are no other noise sources or anything to affect to mains and it resulted in a noticeable improvement along the lines as you described.
Syd
subharmonic wrote:in my home theater the Monster Power 3500 seems to dropped out a lot of noise.
If it did that means that the gear being used is suspect. High quality gear has all the 'conditioning' and noise reduction it needs built in.
Monomer
#20 Post by Monomer »
If I take a meter to a circuit and the voltage drop dips below 100VAC, I'll pull the plug and leave.
-More to come!
WB
#21 Post by WB »
Good point, but things fluctuate. You won't catch it in time during a gig. Anytime long extension cords or generators are involved I like the peace of mind the voltage regulator provides. In most cases it stays at home.
subharmonic
#22 Post by subharmonic »
Not sure what level I need to be at, I use Onkyo 700 series receivers for the last 6 years 701 then a 703 is my current one. I think they sound sweet. Sources were cheapo pioneer, then Onkyo 501? DVD player, then Xbox 360 also. I always thought Onkyo was a good midrange unit.
The gear we tested with the Richard Grey and APC unit was Integra gear (Onkyo's version of Lexus) at the office/shop. Maybe there is an inherent issue with their power supplies that they need a conditioner as all had some degree of improvement.
Too bad I would need to cut a load of plaster to get a dedicated line to my current location, would like to there is a lot of outlets on this circuit.
I need more bass
CW Mcall
