Subs should be touching (or within 6" mouth to mouth), or more than 2 wavelengths apart. At 40Hz, one wavelength is 28ft, and two wavelengths is 56ft.sine143 wrote:I was under the impression that you needed to keep the subs fairly close together, or farther than 50 feet apart? What is the max you can separate them under 50 feet (might make setup a little easier on me)
Tops should be touching (or within 1" piezo to piezo - which still means touching since the top & bottom panels are 1/2" ply) or more than 2 wavelengths apart horizontally. At 100Hz one wavelength is 11.3ft, and two wavelengths is 22.5ft.
--Stan Graves
