DR-250's and Titan 48"s.
SoundInMotionDJ
Re: DR-250's and Titan 48"s.
#16 Post by SoundInMotionDJ »
sine143 wrote:I was under the impression that you needed to keep the subs fairly close together, or farther than 50 feet apart? What is the max you can separate them under 50 feet (might make setup a little easier on me)
Subs should be touching (or within 6" mouth to mouth), or more than 2 wavelengths apart. At 40Hz, one wavelength is 28ft, and two wavelengths is 56ft.
Tops should be touching (or within 1" piezo to piezo - which still means touching since the top & bottom panels are 1/2" ply) or more than 2 wavelengths apart horizontally. At 100Hz one wavelength is 11.3ft, and two wavelengths is 22.5ft.
--Stan Graves
Last edited by SoundInMotionDJ on Mon Apr 05, 2010 2:24 pm, edited 1 time in total.
10 T39S + 10 DR200 + 1 T48
sine143
#17 Post by sine143 »
So... why the advice to separate the subs?
4x Otop12 d2512 loaded
2x AT (1 mcm, 1 gto 804)
1x bastard XF208
sine143 wrote:So... why the advice to separate the subs?
If the room/venue is 60 feet or wider separating the subs by at least 50 feet will often give a more uniform SPL throughout, but if you can't separate them by that much the result will usually be less uniform SPL.
