+1Harley wrote:....and seeing you already have two J110s, then I'd opt for the 3rd J110 and get a different amp.
Three J110's are more than plenty loud enough for a large stage with decent FOH and will also be adequate for some serious backline.
That rich J110 tone gets even better with 3 cabs, plus the height factor gets the sound closer to ear level...plus looks impressive!
Jack 110 First Impressions
- jswingchun
Re: Jack 110 First Impressions
Omni 10
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Omni 10.5
OmniTop 12 x 4
Wedgehorn 8 x 3
T39 @ 18" x 2
T39 @ 20" x 2
T39 @ 28" x 2
Jack 110 x 5
Jack Lite 12
XF210
Harley, for my own edification, would you mind elaborating on why you prefer the OT12 over a Jack when used a with a T39 as part of a bass rig? I understand that the Jack is a full range cabinet and would need to be rolled off somewhere around 100 Hz to stay out of the sub's way, but that doesn't seem like a big deal given that my current head has a variable crossover. How would this be much different than what Gauss did by placing a T39 under his combo? Is this a horn loaded thing?If you're serious about tone and volume for elect bass - which going by your posts you are - then for a top/sub, it'seither OT12/T39 or ( better still ) DR250/T39.
Two J110s for bass (no piezos)
Two J110s with piezos
Currently building SLA Pros and T24s
- Harley
Then just build a T39 and keep with the J110s.jbass wrote:....I understand that the Jack is a full range cabinet and would need to be rolled off somewhere around 100 Hz to stay out of the sub's way, but that doesn't seem like a big deal given that my current head has a variable crossover. ...
But, seeing you have been already bitten by the building bug, why not just make another J110 anyhow, and if you need to later on, a T39.
OK, so a T39 will work under a J110. That's what I was hoping to confirm. My plan at the moment is, as you've suggested, to build a third Jack and see how things go. Realistically, two J110s are probably adequate for most of my needs, but I always like to have more than I need...just in case. And, yes, I've been bitten by the building bug. Thanks for your input.Then just build a T39 and keep with the J110s.
- Harley
So long as you have a crossoverjbass wrote:OK, so a T39 will work under a J110. That's what I was hoping to confirm.
Yes, my primary amp has a built-in crossover. However, I just looked at the manual and found that the minimum crossover frequency is only 200Hz, and I know that's way too high for a sub. And so it goes. Since I've already decided on building a third J110 for now, I'll keep the T39 in the back of my mind as a possible upgrade down the road.So long as you have a crossover
Well, I bit the bullet today and started another pair of J110s. I'd originally intended to build just one, but since I had to buy a full 4x8 sheet of plywood it made sense to cut out the pieces for a second cabinet at the same time. Do I need four cabinets? Probably not, but it'll be nice to have them if I do. In fact, I'm really excited about having a rig which I can scale up or down depending upon the gig (I anticipate using two or three most of the time).
So, now that I know what one J110 sounds like and how adding a second really kicks things up, what can I expect with three and four? And, yes, I do use earplugs
Try this on: use 2 for your bass rig and 2 for the PA.jbass wrote:Well, I bit the bullet today and started another pair of J110s. I'd originally intended to build just one, but since I had to buy a full 4x8 sheet of plywood it made sense to cut out the pieces for a second cabinet at the same time. Do I need four cabinets? Probably not, but it'll be nice to have them if I do. In fact, I'm really excited about having a rig which I can scale up or down depending upon the gig (I anticipate using two or three most of the time).
Yeah, I thought of that. However, both of my bands already have PA or it's provided by the house, so I really wouldn't have the opportunity to use two of the J110s as PA speakers. Besides, if I ever needed PA cabinets, it'd be more fun to just build a couple moreDJPhatman wrote:Try this on: use 2 for your bass rig and 2 for the PA.
Excellent! [Cue maniacal laugh.] I hope that wearing Depends won't make my butt look big onstage. I suppose I could also eat a lot of cheese before a gig.quaizywabbit wrote:poopin yer pants....
