Bruce Weldy wrote:escapemcp wrote: Probably looking at Deltalite for now, and I may upgrade to 3012HO later,![]()
Baffle design and phase plug in the OT12 are different for these two drivers. No upgrade path there. So, if you want the 3012HO - better do it now.
New Build - T30s and then Otops to follow
Re: New Build - T30s and then Otops to follow
Probably will stick with basslite, even though I feel like I am being robbed of £25 on each one! I will be running them off a iNuke3000DSP amp, which puts out about 325W @ 8 ohms, so the HO's would end up underpowered, although not a bad thing, what with power compression. The Deltalite's though would give the amp a bit of headroom, rather than the speaker, and the amps cost moreescapemcp wrote:
OK, now (re)investigating processing options. Have been looking at the Driverack PX, as it comes with measurement mic and RTA (a FAR better deal than the Berry combo of DCX/DEQ AND measurement mic
), but was wondering how much the following things mattered:
1) only 24/dB LR slopes
2) only 3 band PEQ on the main outs <-thought this may be worse than 1)
Probably going to stick with the iNuke 3000DSP, which has everything I need on it's DSP, bar the RTA. As it is only £70 extra for the DSP model, I figure even if I do get a Driverack in the future, then I can just stop using the DSP section (although I love the idea of the limiter being IN the amp=no way for eedjuts to bypass it).
Oh and I have been editing (Audacity) my fave tunes to listen on my new T30 - left channel is HPF at 100Hz/24LR, and right channel is LP 35-100Hz/48LR and hook up the T30 and my sony speaker accordingly. Sounds very nice (although I need a bit more gain on the sub channel for next time). Have only managed to get 5V through the sub before the 'rents start complaining
Puts a big fat smile on my face though
Bill has said in the past something like:
"use the highest value steepest slope available".
So if 24LR is the highest value steepest slope you have, no probs
1) no problemescapemcp wrote:, but was wondering how much the following things mattered:
2) true.... but that's on top of 31 band graphic EQ on the input side. I only use the graphic...don't even engage the PEQs.
OK, many thanks for that. I'm going with NU3000DSP to get me going, then I'll add to that a PEQ2496 for RTA. 2nd system (T60s and DR250s) will use a driverack, and for the 3rd system (Titan + somethingBruce Weldy wrote:1) no problemescapemcp wrote:, but was wondering how much the following things mattered:
The Tuba 30 system (2xT30+2xOT12) has to be built by the 25th of May, as I am planning a party that weekend (to celebrate my new rig - any old excuse for a party
I have just been giving it some stick (well, 5V!) and damn it's nice. Haven't installed the final 2 braces yet in the mouth of the sub yet, so the big unsupported piece on the bottom (24"x30") is vibrating a little
Here you go:
Taken on rubbish Samsung phone GT-S5280
Defy the vortex -of mediocre-second rate bass- produced by mongrels- devoid of taste!
A beautiful lyric from : Maggotron "In Search of a Funky Khan"
4 T60 27" lab15,Omni TB 2 BP102,AutoTubaMCM 10"
Higher power test with better camera... you can hear the sub on this!
A bit annoyed this weekend. Was supposed to have a router delivered on Friday which didn't happen, and also supposed to get more wood but the shop closed early
So there was only one thing for it.... get smashed, but, you've guessed it, didn't even manage that (and I'm usually really good at that
). I therefore just did a few odd jobs (not the Bond villain
Still umm-ing and arr-ing over building DR250's to go with my Tubas, especially after the Deltalite's price hike recently. What would be the recommended 10" driver to go into the DR250s please?
I went out and got smashed for you, don't worry.
118 quid each at lean business.The recommended woofer is the Eminence Deltalite II 2510
Thanks 88, much appreciated88h88 wrote:I went out and got smashed for you, don't worry.
Thanks 88, much appreciated88h88 wrote:The recommended woofer is the Eminence Deltalite II 2510
I have found Radiator Pine @ £26 a sheet and also Latvian Birch @ the same price, although it is more of a PITA to get. Which should I go for or doesn't it matter. Note: I will be Duratexing them.
+ves/-ves please
Many thanks.
+ves/-ves please
Many thanks.
Bas Gooiker
I would take the Latvian (Baltic) birch and suffer a bit of PITA for the premium stuff. No point in taking the best alternative if you can get the right product for the same amount of money. £26 is insanely cheap... just make sure its not thin veneer stuff.escapemcp wrote:I have found Radiator Pine @ £26 a sheet and also Latvian Birch @ the same price, although it is more of a PITA to get. Which should I go for or doesn't it matter. Note: I will be Duratexing them.
+ves/-ves please
Many thanks.
- Rune Bivrin
I wouldn't go with radiator pine. It gets insanely hot.escapemcp wrote:I have found Radiator Pine @ £26 a sheet and also Latvian Birch @ the same price, although it is more of a PITA to get. Which should I go for or doesn't it matter. Note: I will be Duratexing them.
+ves/-ves please
Many thanks.
Radiata pine is OK, on the other hand.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
