New Build - T30s and then Otops to follow
escapemcp
Re: New Build - T30s and then Otops to follow
#121 Post by escapemcp »
Bruce Weldy wrote:
escapemcp wrote: Probably looking at Deltalite for now, and I may upgrade to 3012HO later,
:cop:
Baffle design and phase plug in the OT12 are different for these two drivers. No upgrade path there. So, if you want the 3012HO - better do it now.
:cussing:
escapemcp
#122 Post by escapemcp »
escapemcp wrote: :cussing:
Probably will stick with basslite, even though I feel like I am being robbed of £25 on each one! I will be running them off a iNuke3000DSP amp, which puts out about 325W @ 8 ohms, so the HO's would end up underpowered, although not a bad thing, what with power compression. The Deltalite's though would give the amp a bit of headroom, rather than the speaker, and the amps cost more :broke: so I'll try to give them an easier ride! Also means I don't have to find £400 when I want to build another pair.
escapemcp
#123 Post by escapemcp »
OK, now (re)investigating processing options. Have been looking at the Driverack PX, as it comes with measurement mic and RTA (a FAR better deal than the Berry combo of DCX/DEQ AND measurement mic :broke:), but was wondering how much the following things mattered:
1) only 24/dB LR slopes
2) only 3 band PEQ on the main outs <-thought this may be worse than 1)
Probably going to stick with the iNuke 3000DSP, which has everything I need on it's DSP, bar the RTA. As it is only £70 extra for the DSP model, I figure even if I do get a Driverack in the future, then I can just stop using the DSP section (although I love the idea of the limiter being IN the amp=no way for eedjuts to bypass it).
Oh and I have been editing (Audacity) my fave tunes to listen on my new T30 - left channel is HPF at 100Hz/24LR, and right channel is LP 35-100Hz/48LR and hook up the T30 and my sony speaker accordingly. Sounds very nice (although I need a bit more gain on the sub channel for next time). Have only managed to get 5V through the sub before the 'rents start complaining :bull: Puts a big fat smile on my face though :D
#124 Post by Grant Bunter »
Bill has said in the past something like:
"use the highest value steepest slope available".
So if 24LR is the highest value steepest slope you have, no probs :)
#125 Post by Bruce Weldy »
escapemcp wrote:, but was wondering how much the following things mattered:
1) no problem
2) true.... but that's on top of 31 band graphic EQ on the input side. I only use the graphic...don't even engage the PEQs.
escapemcp
#126 Post by escapemcp »
1) no problem
OK, many thanks for that. I'm going with NU3000DSP to get me going, then I'll add to that a PEQ2496 for RTA. 2nd system (T60s and DR250s) will use a driverack, and for the 3rd system (Titan + something :confused: - probably more DR250s :) ) I am probably going to use the T.rack 2/4 http://www.thomann.de/gb/the_tracks_ds_24.htm as this system won't be used that often. I am reluctant to buy all the same, as I am a fiddler and love to play around with new toys.
The Tuba 30 system (2xT30+2xOT12) has to be built by the 25th of May, as I am planning a party that weekend (to celebrate my new rig - any old excuse for a party :twisted: )
I have just been giving it some stick (well, 5V!) and damn it's nice. Haven't installed the final 2 braces yet in the mouth of the sub yet, so the big unsupported piece on the bottom (24"x30") is vibrating a little :) I won't install the braces until I have managed to duratex the mouth of the sub - light grey in the mouth and black exterior btw. I'll stick some photos up shortly.
escapemcp
#127 Post by escapemcp »
Here you go:
Taken on rubbish Samsung phone GT-S5280
eshadeol
#128 Post by eshadeol »
:!: whoa, don't go buying that stuff unless you are certain that you want tha5 funky blue. Most people get black though.
Defy the vortex -of mediocre-second rate bass- produced by mongrels- devoid of taste!
A beautiful lyric from : Maggotron "In Search of a Funky Khan"
4 T60 27" lab15,Omni TB 2 BP102,AutoTubaMCM 10"
escapemcp
#129 Post by escapemcp »
Higher power test with better camera... you can hear the sub on this! :hyper:
escapemcp
#130 Post by escapemcp »
A bit annoyed this weekend. Was supposed to have a router delivered on Friday which didn't happen, and also supposed to get more wood but the shop closed early :wall: So there was only one thing for it.... get smashed, but, you've guessed it, didn't even manage that (and I'm usually really good at that :cussing: ). I therefore just did a few odd jobs (not the Bond villain :oops: )
Still umm-ing and arr-ing over building DR250's to go with my Tubas, especially after the Deltalite's price hike recently. What would be the recommended 10" driver to go into the DR250s please?
88h88
#131 Post by 88h88 »
I went out and got smashed for you, don't worry.
The recommended woofer is the Eminence Deltalite II 2510
118 quid each at lean business.
escapemcp
#132 Post by escapemcp »
88h88 wrote:I went out and got smashed for you, don't worry.
Thanks 88, much appreciated :(
88h88 wrote:The recommended woofer is the Eminence Deltalite II 2510
Thanks 88, much appreciated :)
escapemcp
#133 Post by escapemcp »
I have found Radiator Pine @ £26 a sheet and also Latvian Birch @ the same price, although it is more of a PITA to get. Which should I go for or doesn't it matter. Note: I will be Duratexing them.
+ves/-ves please :)
Many thanks.
Bas Gooiker
#134 Post by Bas Gooiker »
escapemcp wrote:I have found Radiator Pine @ £26 a sheet and also Latvian Birch @ the same price, although it is more of a PITA to get. Which should I go for or doesn't it matter. Note: I will be Duratexing them.
+ves/-ves please :)
Many thanks.
I would take the Latvian (Baltic) birch and suffer a bit of PITA for the premium stuff. No point in taking the best alternative if you can get the right product for the same amount of money. £26 is insanely cheap... just make sure its not thin veneer stuff.
Rune Bivrin
#135 Post by Rune Bivrin »
+ves/-ves please :)
Many thanks.
I wouldn't go with radiator pine. It gets insanely hot. :slap:
Radiata pine is OK, on the other hand.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
