Page 9 of 10
Re: SLA Pro
Posted: Tue May 10, 2011 7:38 pm
by LEVLHED
those are pretty sweet
I'd probably go with black still, but I can totally see how white works.
Re: SLA Pro
Posted: Thu Sep 29, 2011 3:37 pm
by BoostFab
ewetho wrote:I have used the Pyle Pro PDMW6 in a 6W12T using the GT302 for tweet and it is amazingly clear.
Sorry for waking up an old thread!
Would the Pyle PDMW6 okay to use on the SLA Pro ?
Re: SLA Pro
Posted: Thu Sep 29, 2011 4:10 pm
BoostFab wrote:ewetho wrote:I have used the Pyle Pro PDMW6 in a 6W12T using the GT302 for tweet and it is amazingly clear.
No link, no opinion. And if it's Pyle there's probably no SPL chart to compare anyway.
Re: SLA Pro
Posted: Thu Sep 29, 2011 4:41 pm
by BoostFab
Bill Fitzmaurice wrote:No link, no opinion. And if it's Pyle there's probably no SPL chart to compare anyway.
Specifications:
Power handling: 125 watts RMS/250 watts max • Voice coil diameter: 1" • Impedance: 8 ohms • Frequency response: 70-9,000 Hz • Magnet weight: 25 oz. • Fs: 67 Hz • SPL: 86.9 dB 1W/1m • Vas: 0.36 cu. ft. • Qms: 4.99 • Qes:0.95 • Qts: 0.80 • Xmax: 3.3 mm • Dimensions: Overall diameter: 6.5", Cutout diameter: 5.63", Depth: 3".
http://www.parts-express.com/pe/showdet ... le%20PDMW6
Re: SLA Pro
Posted: Thu Sep 29, 2011 5:00 pm
BoostFab wrote:Bill Fitzmaurice wrote:No link, no opinion. And if it's Pyle there's probably no SPL chart to compare anyway.
Specifications:
No chart. That makes it a pig in a poke.
Re: SLA Pro
Posted: Thu Sep 29, 2011 5:17 pm
by BoostFab
I'm afraid it's a Pyle of.....
If anyone know of an inexpensive alternate to the Alpha6, please share.
Re: SLA Pro
Posted: Thu Sep 29, 2011 5:30 pm
by ewetho
Basic modeling shows the Pyle not as loud and first hand experience I would say the Eminence is easily clearer and more articulate through the midrange and Vocals. Do yourself the favor and save up for the Alpha 6's.
Re: SLA Pro
Posted: Sat Oct 01, 2011 5:59 pm
by BrentEvans
BoostFab wrote:I'm afraid it's a Pyle of.....
Dayton PA-6. I've heard them plenty of times in a design very similar to SLAPro... they work a treat.
I chose them to go in the SLA's that are going in my church soon...
Re: SLA Pro
Posted: Sun Oct 02, 2011 6:07 pm
by SirNickity
Those look interesting. I had not gone as far as comparing specs but I've been interested in building a small supplemental cab out of them. If they work in the SLA design, all the better.
EDIT: Specs are close except Qms, which I don't think matters much. I would be interested in real-world comparisons. $20 a driver is a steal.
Re: SLA Pro
Posted: Sun Oct 02, 2011 11:27 pm
by BoostFab
BrentEvans wrote:BoostFab wrote:I'm afraid it's a Pyle of.....
is it this one you're referring to?
http://www.daytonaudio.com/index.php/pa ... river.html
or
http://www.daytonaudio.com/index.php/lo ... range.html
Re: SLA Pro
Posted: Mon Oct 03, 2011 11:19 pm
by BrentEvans
First one... PA6, not PK6. The PK might work, don't know... but the PAs sound quite good.
Re: SLA Pro
Posted: Tue Oct 04, 2011 11:52 am
by johns811
Re: SLA Pro
Posted: Tue Oct 04, 2011 6:40 pm
by BoostFab
That's great!
I guess I will give them a try for another pair later on. I got the Alpha's from LeLand last week instead.
Re: SLA Pro
Posted: Sun Oct 09, 2011 2:18 am
by Titanium Hand
BZB, your white SLA pro's look fast as
Could you help me out regarding how they are powered please?
I see that you wrote "XTi1000 & XTi2000 powered", but how? For each cab do they have a load of 2ohms? I'm very interested in the SLA's given there size.
Thanks for any clarification in advance
Re: SLA Pro
Posted: Sat Oct 15, 2011 1:34 pm
by bzb
8 ohms each, the 6" are wired series-parallel (IITP).
I've run them on both the XTi 2000 and the 1000... but it doesn't matter much. You'll hear it if you start overpowering them. They're so sensitive you really don't need to put much power into them, anyway.
