SLA Pro
LEVLHED
Re: SLA Pro
#121 Post by LEVLHED »
those are pretty sweet
I'd probably go with black still, but I can totally see how white works.
http://www.livingjukebox.com
9,000 watts and I'm not afraid to use them.
BoostFab
Re: SLA Pro
#122 Post by BoostFab »
ewetho wrote:I have used the Pyle Pro PDMW6 in a 6W12T using the GT302 for tweet and it is amazingly clear.
Sorry for waking up an old thread!
Would the Pyle PDMW6 okay to use on the SLA Pro ?
Re: SLA Pro
#123 Post by Bill Fitzmaurice »
No link, no opinion. And if it's Pyle there's probably no SPL chart to compare anyway.
BoostFab
Re: SLA Pro
#124 Post by BoostFab »
Bill Fitzmaurice wrote:No link, no opinion. And if it's Pyle there's probably no SPL chart to compare anyway.
Specifications:
Power handling: 125 watts RMS/250 watts max • Voice coil diameter: 1" • Impedance: 8 ohms • Frequency response: 70-9,000 Hz • Magnet weight: 25 oz. • Fs: 67 Hz • SPL: 86.9 dB 1W/1m • Vas: 0.36 cu. ft. • Qms: 4.99 • Qes:0.95 • Qts: 0.80 • Xmax: 3.3 mm • Dimensions: Overall diameter: 6.5", Cutout diameter: 5.63", Depth: 3".
http://www.parts-express.com/pe/showdet ... le%20PDMW6
Re: SLA Pro
#125 Post by Bill Fitzmaurice »
Specifications:
No chart. That makes it a pig in a poke.
BoostFab
Re: SLA Pro
#126 Post by BoostFab »
I'm afraid it's a Pyle of.....
If anyone know of an inexpensive alternate to the Alpha6, please share.
ewetho
Re: SLA Pro
#127 Post by ewetho »
Basic modeling shows the Pyle not as loud and first hand experience I would say the Eminence is easily clearer and more articulate through the midrange and Vocals. Do yourself the favor and save up for the Alpha 6's.
BrentEvans
Re: SLA Pro
#128 Post by BrentEvans »
BoostFab wrote:I'm afraid it's a Pyle of.....
Dayton PA-6. I've heard them plenty of times in a design very similar to SLAPro... they work a treat.
I chose them to go in the SLA's that are going in my church soon...
SirNickity
Re: SLA Pro
#129 Post by SirNickity »
Those look interesting. I had not gone as far as comparing specs but I've been interested in building a small supplemental cab out of them. If they work in the SLA design, all the better. :-)
EDIT: Specs are close except Qms, which I don't think matters much. I would be interested in real-world comparisons. $20 a driver is a steal.
BoostFab
Re: SLA Pro
#130 Post by BoostFab »
is it this one you're referring to?
http://www.daytonaudio.com/index.php/pa ... river.html
or
http://www.daytonaudio.com/index.php/lo ... range.html
BrentEvans
Re: SLA Pro
#131 Post by BrentEvans »
First one... PA6, not PK6. The PK might work, don't know... but the PAs sound quite good.
johns811
Re: SLA Pro
#132 Post by johns811 »
I built with the daytons and sounds fine to my ear.
http://billfitzmaurice.info/forum/viewt ... 13&t=15103
BoostFab
Re: SLA Pro
#133 Post by BoostFab »
johns811 wrote:I built with the daytons and sounds fine to my ear.
That's great!
I guess I will give them a try for another pair later on. I got the Alpha's from LeLand last week instead.
Titanium Hand
Re: SLA Pro
#134 Post by Titanium Hand »
BZB, your white SLA pro's look fast as 8)
Could you help me out regarding how they are powered please?
I see that you wrote "XTi1000 & XTi2000 powered", but how? For each cab do they have a load of 2ohms? I'm very interested in the SLA's given there size.
Thanks for any clarification in advance
bzb
Re: SLA Pro
#135 Post by bzb »
8 ohms each, the 6" are wired series-parallel (IITP).
I've run them on both the XTi 2000 and the 1000... but it doesn't matter much. You'll hear it if you start overpowering them. They're so sensitive you really don't need to put much power into them, anyway.
Bobby Shively
Purveyor of fine aged hip hop
Powered by XTi 1000 & 2000
