Re: 2 x T30 Slim Build Log
Posted: Sun Oct 13, 2013 6:49 pm
Sunday
Almost there! Just a few reinforcing panels to go and the side is going on!!
I did just make a bit of a cock-up, so rather than rushing in to fix it I called it a night in order that I (& you
) can think how to best work around the problem. The issue is that I have run my wires out of the holes in the rear of the cab, but I have forgotten to route the recess for the round speakon connectors.
This is on the rear of the cab behind panel 13. Panel 13 has been glued in place, so access is very limited. I think I have a plan involving string and a wire coathanger with a hook, so I'll try this out tomorrow. I just don't want to lose that wire through that hole, or that will be a whole lot of fiddling to get it back out!!
Pic 1 shows the 2 piece braces, which I found easier to construct than a one piece due to me fast running out of BB! I wasn't planning on quite such a gap between the 2, but I think it'll be ok, especially as I have double braces when I should only have a single one.
Anyway, that's all for today. Busy day tomorrow... unfortunately not speaker related
