Throat sides and supports...
Assembled horn throats...
Attaching the woofer baffle...
Baffles attached and vent slots cut out on the first two...
Driver spacers and baffle flanges installed...
Throat fillers and h-nuts for driver mounting installed...
Tops and bottoms cut and lines drawn...
Top and bottom attached on first one...
The stack...
Test fitting the driver and melded array...
That's all so far folks. Slow and steady...
 Like you, the only time I have to work on them is at night and early morning before everyone is up. And it's kind of hard to run a saw while the rest of the neighborhood is asleep.
 Power tools and drinking?
