maxmercy wrote:Just because you have an oversize side does not mean you don't have to use registration pegs/pins...the registration pins help keep that side from sliding around on that cushion of PL...
JSS
MaxMercy,
The reason I cut it oversized was because my current 36x36 piece would require some serious clamping to get it to fit perfectly without any sort of lip all the way around from the vertical panels. This AraucoPly is really warpped
. With the larger side panel, now I don't have to worry about the crazy clamping to get it to fit right. I can use those clamps instead to compress the side panel to the vertical panels. I definitely plan on using registration points.
Here is my plan once the mouth is fully Duratexed up:
1) clamp opposite panel
2) mark the side panels by digging inside the horn mouth as much as I can tracing the outline. And inside of the access panel, panels too.
3) Where I couldn't reach in side the horn, measure from other panels and mark accordingly on side panel
4) Drill all pilot holes in side panel using tracing as a guide
5) Remount side panel aligning to trace and clamp
6) Redril through existing pilot holes into actual vertical panel edges
7) Remove side panel and apply a TON of PL to the edges of the vertical panels. Especially in the places where it's uneven (out 1/16")
Using 4 - 6 screws, screw them in slightly through the side panel so they poke out enough to act as registration pins
9) With help from my wife place side panel onto vertical panels laced with PL, aligning screws to the predrilled vertical panel holes.
10) Tighten these screws and continue to screw until entire side panel is secure
Sound okay? Any suggestions would be appreciated.
