Im mid-build of a pair of 20" T39's with a 3012LF in each, and im looking at amp options.
the 3012's are 8 ohm, but i'm sure i read somewhere on the forums that in a horn loaded enclosure, the effective impedance is reduced. anyone know how much by? I will not always run them as a pair - sometimes just one will be enough, so my amp option needs to be flexible.
I'm going to use Hypex UcD class-d modules to run the pair. if i were buying bits from scratch, i'd just go a single UcD-700 and run the pair in parallel. *but*, i already have a UcD 400 module sitting here. so the cheap option would be to get another one, and run them bridged, with the T39's in parallel. or i could run one module per sub. then if i'm just using one sub, i can just use a single UcD400 channel. I could always sell the UcD400 and buy the 700 tho.
I'm also wondering how much power a 20" 3012LF T39 can take. Ive also read somewhere that the T39 design is the limiting factor, not the 3012LF. is that the case?
too many options!!!
anyone got anything to say that might help me make the decision?
cheers,
ben
