From another thread, the Acrytech people say to apply HB at the rate of 160 square feet per gallon.
Ballpark, this is about 1 quart per T48.
You guys drinking this stuff?
Re: You guys drinking this stuff?
- Harley
What type of roller did you use to create the texture?LelandCrooks wrote:I then rolled on another moderate coat, then a heavy one which I textured. .
A sheet of cheapo dropcloth plastic, thinner the better, cut approximately the same size as the panel in question. Roll on a fairly heavy coat, stick the plastic on it. Lightly rub it with your hands. The more wrinkles the better. Peel it off. Takes a little practice. If you don't like it the first time, roll on some more and do it again.
