I believe both will work well, as described in the stacking and placing subs sticky:
http://billfitzmaurice.net/phpBB3/viewt ... ?f=1&t=398
Quote:
Here's the same treatment applied to Tubas.
With more than 2 cabs stack them above the first two.
Or go side by side:
With side by side clusters of Tubas the space between the mouths of the cab pairs is pretty wide, limiting how high a frequency the two cab pairs will couple to. T36s would have to be crossed over at 70 Hz, or less, T30s at 80 Hz or less and T24s 100 Hz or less.
EndQuote:
Not sure what the numbers are for the coupling of THTs when you go side by side, or what shape the coupling plate would best be for THT since it doesn't have the mouth flare of the Tubas or Titans, but I bet Bill knows offhand...looks like if you could stack them in two columns you could crossover higher to the tops...
JSS
