Impedance sweep?
Rick Auricchio
Impedance sweep?
#1 Post by Rick Auricchio »
I've seen mention of running an impedance sweep to find air leaks.
I believe I understand the concept: You measure driver impedance over its frequency range to spot unexpected peaks. The normal cab tuning should cause a peak; something else indicates odd tuning, from a leak.
Tools needed: Signal generator, impedance meter.
So what's an economical impedance meter, a method using one or more multimeters, or a combo device that runs the sweep?
Sydney
Re: Impedance sweep?
#2 Post by Sydney »
So what's an economical impedance meter, or a combo device that runs the sweep?
Define economical...A Woofer Tester II ( $159.95 )
http://www.woofertester.com/wt2product.htm
It generates an impedance sweep and T/S parms in a few minutes ( including calibration )
* Some impedance meters only offer a single frequency test - Not a sweep of all frequencies
The old school method ( which involves manual recording/plotting ) requires:
A sine wave generator ( w frequency counter )
An AC volt meter
An accurate resistor ( for calibration )
And optional but ideally - an oscilloscope
Rick Auricchio
#3 Post by Rick Auricchio »
$159 isn't bad, but unless I'm building a lot of cabs it's a bit on the high side.
Sydney
#4 Post by Sydney »
Valid point
For me - building cabs for a long time now, and planing on building many more in the future - It was a investment.
If you have to buy the individual items ( I listed ), for quality/accurate generators/counters/ and meters you can easily exceed the cost of a WTII.
Also manually recording and charting detail and doing T/S measurements is a boring & tedious and takes a lot longer than a few minutes.
Of course, there are test jigs and software that utilize a sound card as a measurement device - BUT I tried several and found the software clumsy and I wasted a lot of time just trying to get it to work.
That's not to say you can't build a jig and download software and get it to work.
You will have to invest some time in set up.
You can be up & running w WTII immediately - software is continuously being updated with additional functions being added, and upgrades are free ( so far ).
WTII generates an impedance curve w the electric phase over-laded.
It's about a user's friendly as possible.
kdchandler
#5 Post by kdchandler »
Last year (I think) there was a discussion about the Woofer Tester and someone mentioned a similar product from which the WT was derived. The other unit was described as more capable, but I can't find it with the search. Does anyone remember the other box?
Thanks
4 DR200, 6 TLAH (semi-pro)
4 T39 (20" BP102), 2 TT ( 1 ea W8-740C, HL10A)
2 Wedgehorn 6, 1 Wedgehorn 10
Rick Auricchio
#6 Post by Rick Auricchio »
Though I have a PC I rarely use, I'd prefer a Macintosh program. A little searching turned up:
http://supermegaultragroovy.com/products/FuzzMeasure/
which might do the trick for US$150. I've got the audio interface for my MacBook Pro, and I've downloaded the demo version.
#7 Post by Bill Fitzmaurice »
kdchandler wrote:Last year (I think) there was a discussion about the Woofer Tester and someone mentioned a similar product from which the WT was derived. The other unit was described as more capable, but I can't find it with the search. Does anyone remember the other box?
Thanks
http://www.partsexpress.com/pe/showdetl ... er=390-804
kdchandler
#8 Post by kdchandler »
That was too easy. :roll: The one I imagine remembering was a different company of which I'd never heard, but it looked similar. Does the WT3 work well?
Sydney
#9 Post by Sydney »
From my understanding:
Smith & Larson Audio was the original source of the WT ( which at one time PE sold - I got mine there).
They had a parting of the ways, & PE went on to sell WTIII.
S & L sells WTII and other products.
They offer free software upgrades for original purchasers of WTII and the TENMA version.
You can calculate T/S parameters, other resonate circuits, test basic parts,
It also has these modules: Box Alignment, advanced Thiele-Small Simulator & Box Analyzer
also a speaker burn-in function.
WTIII is Supposed to be a stripped down version of WTII. Go figure.
* Also TENMA (MCM) sells a version of WTII.
Smith & Larson also support this
kdchandler
#10 Post by kdchandler »
Thank you. This was it!
I spent some time reading the WT3 reviews. The simple reviews are mostly thumbs up. The detailed reviews are more varied. They do have a special that includes a digital scale with the WT3 for $99.88 and free shipping. This is a good deal it it works well.
Has anyone used both it and the older units?
remix
#11 Post by remix »
I've had 2 of the old WT2 from PE, both are now dead, went up in smoke. :(
Think i'm going for the original WT2 this time.
Dag
VAN GOGH was an artist years ahead of his time. in fact, he was so far ahead of his time that everyone thought he was wacky. He wasn’t wacky, he was a visionary.
Sydney
#12 Post by Sydney »
Do you know what caused it or what your were doing at the time?
Mine is also a Harris Tech ( purchased from PE ).
After it went out of warranty - I had left the "box" ( it is a modified USB external sound card ) after a sweep and it was generating a low frequency tone on a woofer.
I had forgotten about it ( for hours ), until I smelled the tell tale odor of hot circuits.
Based upon the impedance/phase load ( low and negative ) of that woofer at the held frequency - I think I was putting a worse case load on the 5V USB line with a lot of current draw.
So now I am careful not to hold any generator at these low impedance/ negative phase valleys for extended periods.
Since then, no problems w latest software upgrades from S&L.
remix
#13 Post by remix »
Sydney wrote: Mine is also a Harris Tech ( purchased from PE ).
I did the same with the last one i had, i think that was the problem.
The first time i blew it, it was my mistake, i pushed the cone in and out with the wires connected.
I think that generated current that the box could not cope with.
Thinking about it afterwards its a dumb idea, but it is not statede i the user manual not to do this.
Dag
marty
#14 Post by marty »
i got one of the wt3 things last week, and so far i think it is a piece of crap.
maybe i dont know how to use it properly yet, or interpreting the graphs it makes.
was trying it out on deltalite 2512 and piezos of various kinds
bgavin
#15 Post by bgavin »
I've read far too many failure stories about this CCS, so I decided to keep looking for a better solution. I'd like to find something that will integrate well with the TrueRTA sweep.
Perhaps I don't understand the nature of impedance sweeping yet, but if TRTA can accurately read microphone voltages in a quick sweep, there is no reason it cannot do the same for voltages used to measure impedance.
