The first 6 went into combat unfinished. Even without the crossovers and throat fillers they performed very well.
A stack of 3 per side at any volume is pleasing and easy to listen to as well as high enough to cover anyones ears.
Compared to a real, massive line array I heard a couple of days later, they filled space so well off-axis that the "real" line array well
For the people right on top of the cabs and those directly in front of the stage, the soundfield was very intelligible and full but not as brutal as my expensive bi-amped cabs can be. They take some getting used to as they have a very different sound than most are used to. Ear fatigue at higher volumes is reduced to almost nill due to the smoothness of the boxes and the point source type arrangement. One thing they do not do is overpower the room with that beamy titanium horn sound some people love. The room's acoustics do play a big part in long throw response. They are a very nice fine tool to work with, easy to mix on, and quite transparent. I was taking into consideration the slight upper mid loss due to the lack of the crossover.
I STRONGLY recommend a stack of 3 per side off of a high quality amp for almost any full band playing smallish clubs.Especially top 40. At moderate volume the nearfield dispersion fills that dance floor right in front of you with a curtain or wall of sound that people love because it pulls them into your act. Less ear fatigue means more people staying on the dance floor and in the club. Smoother response and better falloff means the bartenders can talk over or through the system, while the singles can pick up dates, and the club makes money, which is why you are there in the first place.
The final result is more work for you whether you are the band or the sound contractor
