Last year, I built six AT10s (HL10C loaded) and arranged them in a 3Hx2W sixpack stack for last year's event. This year's music festival, I put them in front of the stage six wide and they acted as stands for the monitors. The stage was only a foot tall, so I couldn't put them underneath. Also different this year, I ran them with three channels off a set of QSC PLX2402 amps for around 1200W per pair run in parallel. I limited to 42V output.
Suffice to say, the bass was just awesome. Power alley was a bit strong due to the horizontal array, but the sweet spot was doing a perfectly calculated 107 spl average with undistorted peaks to 118 (C weighted). pre-eq was a 60Hz lowpass 18db/oct. xover was 90Hz. high-pass set to 28Hz. Graphic was minimal.
The third act was a hip-hop/jazz/fusion thing and used drum triggers and exercised the subs quite nicely. The drum set had a great sounding kick, too, which was easy for Jeff doing the knob twisting to get a good sound for the other acts. Chest thump was ungodly insane to the ones dancing up in front for the last act
Oh, and speaking of Jeff... The bum works for Digidesign and brought a D-Show console on loan. What an insane board! We were lucky to have his involvement for FOH.
Not surprising, the Cliff & Dan team won the chili cookoff this year.
