Nice handle option for DR
Tim A
#1 Post by Tim A »
I took a chance on this hoping it would fit. It does, barely. It will set right in between the butt cheeks on a 200 without touching them or having to extend the back. The handle is comfortable to grip, plenty of room for knuckles.
To make the 1/4" back strong enough I cut a strip of 1/2" ply just wide enough to fit between the cheeks and sit flush with the top and bottom, then installed the back over it. Routing was done as a unit, but before the back was installed on the cab. The four screws that hold the handle on use T nuts, the remainder use 1/2" screws.
http://www.partsexpress.com/pe/showdetl ... er=262-826
Sydney
#2 Post by Sydney »
This allows you to carry 1 in each hand? ( cool )
Tim A
#3 Post by Tim A »
Yes. You could do this with a 250 as well. 280 would probably be out of the question unless you swing from trees and eat lots of bannanas!
Dave Non-Zero
#4 Post by Dave Non-Zero »
nah, after exhaustive testing i found that it was prohibitively difficult to eat a banana whilst swinging from a tree, carrying a dr280. maybe with an assistant or possibly a prosthetic banana feeding device....hmmm, back to the drawing board...
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
#5 Post by LelandCrooks »
Lift, don't yank. I had a pair of those in t24's at one point. They would break the handle out if you jerked the box up. As long as you are nice to them, they'll be fine. Teenage boys didn't understand lift not yank.
#6 Post by Bill Fitzmaurice »
LelandCrooks wrote: Teenage boys didn't understand lift not yank.
They have difficulty weight lifting as well, not grasping the concept of clean and jerk as opposed to the opposite order. :roll:
klocwerk
#7 Post by klocwerk »
http://instantrimshot.com
