I can't tell you how happy I am with the outcome. The speakers sound fantastic! I'm using these for powering the digital slide presentations I put together (sound tracks built in Garageband). I am a semi-professional photographer. Thanks to the O15TB's the sound tracks are now larger than life!
I'm powering these with a QSC PLX1802 with a DBX DriveRack PA.
Here are a few images from my build...I should tell you that I did take some of David Perry's ideas (putting a corner handle at the top back corner of the cab and adding corner casters). I also extended the front edge of the cabinet sides 1/2" in case I ever want to add a metal speaker grille. The handle and casters are life savers...makes the cabinets much easier to transport.
Thanks to everyone that helped me trouble shoot this build as it progressed! A special thanks to Leland...I ordered all of the parts for this build from him and it was a HUGE time saver.
P.S. 5/26/08 - I just posted some additional images today - look further in this post if you want to see more images from the build. I hope these pics help you with your construction!
Check out the missing jumper from (-) to (-) and the fact that I mounted both coils in the same axis. I rotated one coil 90 degrees and remounted it to correct this in the end on both the mid-range and tweeter crossovers.
A friend provided me with acoustical grade foam and a pressure pot for applying the Duratex. Finished! (I built two of these; each is a mirror image of the other so that I can stack them for long throw situations or book them at 90 degrees for a short throw set-up).
