Brad nails vs screws
rwalkerphl
#1 Post by rwalkerphl »
Hi Guys,
I am having some issues with using screws on my O10 cabs. I am using Arauco ply for the cabs, and as much as half the time, the ply is splitting, even though I am pre-drilling.
I am thinking about investing in a brad nailer, and wanted to get opinions on whether this is the right way to go?
Thanks,
Robin.
Tim A
#2 Post by Tim A »
Absolutely. Get an 18 gauge nailer, saws and routers will go right through them with no ill effect. If you don't have a compressor already get one large enough to run the spray gun for Duratex, if you're so inclined.
rwalkerphl
#3 Post by rwalkerphl »
Great, thanks Tim! I already have the compressor, so I am good to go.
mjm
#4 Post by mjm »
The 18 gauge nailers really speed things up. But if I need to pull the ply together I use # 6 cabinet screws. They will help with the splitting out problem caused by drywall screws.
Tom
#5 Post by Tom »
Quarter inch air staplers can't be beat for stapling plywood boxes together. The brad nailer is my second choice.
WB
#6 Post by WB »
Tom wrote:Quarter inch air staplers
What size staples are you using? What works best for joining 1/2" plywood?
Tom
#7 Post by Tom »
I use a one inch long staple, and set the nailer to sink it below the first layer of plywood. Some brad nailers will shoot a quarter inch staple as an option. Staples don't blow through as much as brads IMO.
