Links to everything you need for your BFD-build, in Europe.
Polyurethane glue is easy to find, finding it at a reasonable price is the hard part. For a while, the only glues I found were €14 per tube (310ml), Bison and Pattex. Screwfix have a cheap alternative for those in the UK, but they don't ship to the continent. At Hornbach I found Soudal 60A Constructielijm, I think it was about €7 per tube. Works OK for me.
Cannot order online. Since Hornbach is German, I guess it can be found in Germany too.
Warnex supplied this to me some 2 years ago so the figures may have changed but I imagine not drastically:DAVID_L_PERRY wrote:This is the manufacturers web site, should be able to sort out a distributor from here.
http://www.warnex.de/
Pos. Item-Number Article description Price in EUR per kg
01 74.49.001.3 WARNEX one component waterborne
texture paint, black half matt
* 24 kg – 108 kg 8,75 EUR
109 kg – 719 kg 8,25 EUR
720 kg and more 7,95 EUR
Prices of other special colours have to be calculated after naming the colour in RAL or handing over a sample
Packaging costs: per Pallet 15,50 EUR
(28 tins each of 12kg per pallet in summertime)
(25 tins each of 12kg per pallet in wintertime)
per Carton 1,90 EUR
( 1 tin each of 12kg per carton)
Special charge for
small quantities: 24 kg to 48 kg 30,00 EUR
49 kg to 99 kg 15,00 EUR
more than 100 kg without special charge
Size of pails: 12 kg
Minimum quantity
per order: 24 kg
Line X
FYI, Line X is available in the UK.
http://www.line-x.co.uk/
I have also found the Selenium Horn for the O15 at
http://www.nuloop.com/
though I understand this is not that crucial, as long as you get a horn with similar dispersion characteristics.
The prices per kg are very nice, but I don't think I will ever use 24kg. Hard to find small quantities of Warnex for the DIY-er. Aldcrofts don't ship to the continent in small quantities either.0vid wrote:Warnex supplied this to me some 2 years ago so the figures may have changed but I imagine not drastically:DAVID_L_PERRY wrote:This is the manufacturers web site, should be able to sort out a distributor from here.
<snip>
Minimum quantity
per order: 24 kg
http://www.bluearan.co.uk
They sell Aldcrofts in tubs of 2.5 Kg
Poplar Ply
www.avonplywood.co.uk
carries 12mm Italian Poplar ply, decent pricing based in Bristol.
Get in touch with Paul Williams if keen.
They don't ship to mainland Europe0vid wrote:http://www.bluearan.co.uk
BF cabs built to date:
2x T48 21" 3015LF; 1x T48 24" 2xBP102; 1x DR250 2510 loaded, cross firing; 4x DR200 Beta 8, melded array; 1x TT HL-10c; 2x WH Beta 8, melded 'array'; 3x AT 15" Tang Band W8-740P; 1x AT 15" JBL GTO1014
- Dave Non-Zero
just got a 5kg tub of aldcroft form bluaran. was packed great. tub itself was taped shut with electrical AND gaffa tape and then it was packed in bubble AND polystyrene peanuts and then in a cardboard box, inside the larger box the rest of the order came in.
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
1 x TAT
In Progress:
2 x DR280
Tell that to FedExBill Fitzmaurice wrote:Only if you drink it.thijs666 wrote:They tried, though. FedEx refuses to deliver paint, they say it's a hazardous substance.
Re: Links to everything you need for your BFD-build, in Europe.
decent quality countersink bits can be one of the most valuable tools you could own, after some searching i finally found these.
http://www.trend-uk.com/en/UK/productli ... sinks.html
i got the snap/cs/4, produces a nice 2mm hole and a good countersink hole and the depth of the drill bit is adjustable.
they are also available in tungsten.
i can also recommend ebay for various items, i got acoustic foam, styrofoam, cabinet paint and other things from ebay within the uk
good service, speedy delivery.
+1 for the Tuff Cab paint from BlueAran. Delivered to Ireland extremely well packaged.
Does anyone know where I can source the MCM-55-2421 driver for a T-18 in Europe? I currently have one on order from an ebay seller in the States but due to the recent hurricane their ordering/shipping has been heavily delayed. Since I want to make a second T-18 anyway I am going to need another driver so I may as well try to source something from Europe if possible whilst I wait for the one from the US. MCMelectronics in the States won't ship to me here in Ireland either unfortunately.
Thanks in advance.
Thanks in advance.
I don't think you can get the MCM from resellers in Europe. The Tangband 8 is available from several places. You can PM forum member sabbelbacke. I got mine from Herzi, see website HzH Audio.
- Rune Bivrin
Re:
You can get the black from Thomann http://www.thomann.de/gb/warnex.html in 1 or 12 kg quantities. 1kg was quite enough for one Omni 12 Tallboy. They'll ship anywhere in Europe, and are very quick to ship.AntonZ wrote:The prices per kg are very nice, but I don't think I will ever use 24kg. Hard to find small quantities of Warnex for the DIY-er. Aldcrofts don't ship to the continent in small quantities either.
In build order:
O12 with no tweeter.
3 x WedgeHorns.
2 x Jack 10 without tweeters.
2 x DR250.
2 x 16" T39
1 x Tuba 24
2 x SLA Pro (sort of...)
3 x WedgeHorns.
2 x DR250.
2 x 16" T39
1 x Tuba 24
That is very good news! We don't have a European Leland clone, nor do we have "Northern European Sound & Light"
, but gotta love Thomann. Thanks Rune.
