EQ Settings for DR250?
- David Carter
The EQ settings I've been using for my DR250's so far have been based on Dave Perry's DR280 EQ curve found here:
http://billfitzmaurice.com/phpBB2/viewtopic.php?t=2639
Dave had talked recently about gettings some updated pics of his more recent adjustments to those settings, but now that he's sold off the DR280's, I don't imagine we'll be seeing those.
Who's got some info they could share about EQ settings that have worked for you with DR250's?
Dave
- 2 x Titan 39 (BP102 - 14"W)
- Chris_Allen
- David Carter
Ah, I missed that part of the discussion. Well, Dave, if you still have the old rig, I'd love a snapshot of your EQ curve before you hand it over.Chris_Allen wrote:Dave mentioned that he still had a couple of gigs to do with his rig, so I don't think DNZ is the proud owner yet.
Dave
Dave: Don't know if you've ever tried this before, but it's fun and can be a learning experience. I know I learned a lot more about identifying certain ranges by ear.
Anyway, you can get a reasonably decent EQ by using the SPL chart. Here's the one with the melded array. I drew a red line at about 105dB. Using that as a baseline, adjust sliders an appropriate amount to get the response flat. Ie: 150-175 Hz is about 2dB hot, so bring them down 2dB on the EQ. 250 Hz is about 2.5-3dB light, so bring it up that amount. After you get it flattened out based on the chart, you can make final tweaks by ear.
You don't have to use 105, I just put a line there for reference. Do try and pick a center point so you're boosting some and cutting some.
It's not perfect but you can get pretty close.
- David Carter
Thanks, Tim. I hadn't ever thought of that before. Sounds like a good learning exercise. I'll give it a shot sometime this week.Tim Ard wrote:Dave: Don't know if you've ever tried this before, but it's fun and can be a learning experience. I know I learned a lot more about identifying certain ranges by ear.
Dave
- DAVID_L_PERRY
- Chris_Allen
You're just doing manually what the auto RTA does, which is to measure the cab response and then adjust the sliders accordingly.David Carter wrote:Thanks, Tim. I hadn't ever thought of that before. Sounds like a good learning exercise. I'll give it a shot sometime this week.Tim Ard wrote:Dave: Don't know if you've ever tried this before, but it's fun and can be a learning experience. I know I learned a lot more about identifying certain ranges by ear.
- David Carter
Tim Ard wrote:
* EQ is set to +/-6db
* As discussed previously in another thread, I tried to roll off the low end to protect the driver.
* I didn't drop 8K and 10K as much as the curve above called for because I liked the sound better.
*I left 20K flat instead of boosting it because I didn't want to chance blowing anything at higher levels and I couldn't hear the difference anyway.
I like the results very much!
Dave
With live sound I kill 20kHz entirely, as you can't hear it anyway and most sources, both instruments and mics, don't go that high. For that matter I've never done a concert RTA that showed significant content above 12.5kHz.alanstar wrote:I like to boost at 20k, even though you may not noticibly hear it straight away, I think it can add a subtle crispness to the sound.Tim Ard wrote:Nor could anyone you know.David Carter wrote: I left 20K flat instead of boosting it because I....couldn't hear the difference anyway.![]()
