Cab corners
MikeHunt77
Cab corners
#1 Post by MikeHunt77 »
I've tried searching, but the search on the forum appears to be broken. :(
I'm after some corners, and the only ones I've managed to find that fit the bill are in the US:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0185664009
All I need is for them to fit on an array of AT's, and allow them to be stackable.
I was wondering if anyone else had used these and are they any good?
"You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer" - Frank Zappa
Tom
#2 Post by Tom »
Those will work fine with the recommended screws.
They shape pretty nicely if you have to size them to allow removal of an access panel.
Plastic breaks, maybe you should keep a couple extra around when it happens.
MikeHunt77
#4 Post by MikeHunt77 »
Yep, I'll be sure to order a few extras - I always try to do this with stuff that comes from the US.
Stu: This is the closest thing I could find:
http://www.wle-shop.co.uk/modules/shop/ ... de=853.116
I guess it would work but there is no dimensions or much info about them on the site. :(
Alien
#5 Post by Alien »
Have you tried Adam Hall?
http://www.adamhall.com/de/AH_K--Flight ... --19__f--1
Reasonably priced, good quality stuff, and good service all the times I used them.
Andy
Strapping Young Stu
#6 Post by Strapping Young Stu »
MikeHunt77 wrote:Yep, I'll be sure to order a few extras - I always try to do this with stuff that comes from the US.
Thats what I bought for use on my wedges, havent had a chance to finish them yet.
The corners themselves are ok, they are quite thin and dont seem that strong but then again if they are too stiff they tend to crack easily.
They are about 2" square
Stu
MikeHunt77
#7 Post by MikeHunt77 »
Alien wrote:Have you tried Adam Hall?
Andy
They seem to do the stackable corners, nice. :) The only problem is that I cannot order from them - it keeps trying to take me to a reseller than says there aren't any near me. Do I have to make an account or anything like that?
Alien
#8 Post by Alien »
MikeHunt77 wrote: They seem to do the stackable corners, nice. :) The only problem is that I cannot order from them - it keeps trying to take me to a reseller than says there aren't any near me. Do I have to make an account or anything like that?
Not sure if they've changed their setup - it's been about a year since I last ordered from them. I usually order by phone though, so maybe that's the difference.
Andy
MikeHunt77
#9 Post by MikeHunt77 »
Andy
I'll try ringing them and see if they can help - thanks. :)
DAVID_L_PERRY
#10 Post by DAVID_L_PERRY »
Pretty sure you have to have an account with them to order components direct. I have had one for about 10 years now from when I started making flightcases (just found out last weekend that one of my first cases is still on tour with Chubbby Brown !)
I just phone up to place an order. Nice people to deal with and very quick to ship items (as long as they are in stock...)
Dave
MikeHunt77
#11 Post by MikeHunt77 »
DAVID_L_PERRY wrote:Pretty sure you have to have an account with them to order components direct. I have had one for about 10 years now from when I started making flightcases (just found out last weekend that one of my first cases is still on tour with Chubbby Brown !)
Dave
Haha, it must be a good case to last that long! I've managed to do some more googleing, and I found a few DJ type stores selling them...
http://www.djkit.co.uk/product.php?id=2 ... ght=corner
http://www.thomann.de/gb/adam_hall_4102_kugelecke.htm
http://www.quasarelectronics.co.uk/khxc ... 3.127.html
http://www.ukdj.com/index.asp?PageActio ... rodID=8484
Also CPC have quite a few parts...
Basically, use google.co.uk, and get it to search thru UK only sites. :
I'll order some from thomann as I need some Beta 8's anyway for some DR200's. :)
Also, how hard is it to make your own flight cases? I quite like DIY, and am tempted to try making some for my 1210's and mixer. Is it simply a case of making a box and a lid, then bolting on all the extrusion, corners, handles, etc.?
Sydney
#12 Post by Sydney »
Not hard... I have a friend who just completed a case for his Mackie 24 chl.
He has made several in the past for other boards. Some were made to allow the mixer to stay in the case, in operation and ONLY the top was removed for hook up and operation.
Made from 3/4 plywood and foam lined, and vinyl covered with aluminum extrusion along all edges. Heavy but durable.
Dave Non-Zero
#13 Post by Dave Non-Zero »
3/4 INCH PLY for a Mixer case! WOW! that will be one heavy mother! Not even the touring Midas desks have 3/4 inch cases! Its bad enough when the desk weighs quarter of a tonne, never mind the flight case. :D
Built and/or own:
8 x T48 24" 3015LF
6 x DR280
2 x DR250 old style beta10
2 x T36s 20" delta15L
1 x TAT
1 x dual Lab12 30" T60
In Progress:
2 x DR280
Sydney
5/8" ply - but still heavy
#14 Post by Sydney »
I'll verify and correct if I'm wrong on the 3/4. But I can attest it is heavy.
( those plastic cases are so light and unfortunately - expensive )
* Correction it is 5/8" PLY - The owner reckons he could have made it out of 1/2 - as the aluminum edging strengthened significantly.
It has a suitcase handle - But in reality, 2 guys ( over 50 ) tote it in.
gdougherty
#15 Post by gdougherty »
Built a case out of 1/2" Auroco with 1x1" reinforced corners all around and two 1" strips of 1/2" ply on edge across the long dimension of the bottom. Angled the cut for the lid and lined it all with 1" and 2" Polystyrene to protect the board. Built a plate with castors that ratchet straps to the bottom side when it's all closed up. It's a 32 channel Soundcraft Spirit 8 board and everything to buy custom was in the $800+ range for a leave-in case model. Materials came out just under $200.
Still would like to do some HD edge protection on it, but it's holding up just fine without. Mostly it'd stop the ratchet straps from rounding the edges but I should route them anyway so that's no biggie.
