TLAH tight space
tfoust
TLAH tight space
#1 Post by tfoust »
For those that have built the TLAH triangle config how did you manage to put mounting screws inside next to the side panel? Before you tell me to mount the drivers on the front of the baffle the recommended driver (I bought) is designed to mount on the back. The edge of the cone is meant to be held secure by the pressure of the frame pressed against the back of the baffle. It’s going to be a trick getting screws inside the space between the driver and the side panel.
Re: TLAH tight space
#2 Post by Bill Fitzmaurice »
What driver is that? Pretty much every driver made today will mount from the front or back. Drivers don't rely on pressure of the frame against the baffle to hold the cone in place, that's accomplished by the surround and spider.
tfoust
#3 Post by tfoust »
Goldwood Sound GW-4028/S
#4 Post by Bill Fitzmaurice »
That can be front mounted.
tfoust
#5 Post by tfoust »
OK, thanks.
jimbo7
#6 Post by jimbo7 »
I plan on making my triangle TLAH's soon. Are you documenting the build?
tfoust
#7 Post by tfoust »
No
tfoust
#8 Post by tfoust »
I will entertain questions though
#9 Post by Tom Smit »
tfoust wrote: Mon Apr 20, 2026 2:12 am I will entertain questions though
Hah! Okay! How is the build coming along? :)
shawn_g
#10 Post by shawn_g »
What's your favorite food?
I'll see myself out.
tfoust
#11 Post by tfoust »
In suspension just now. Work got in the way. I have both units built to the point of attaching back panel. The first one is wired. Have yet to wire the second. Filters are made. Should be back at it in the next week.
