First Build : Plywood Sourcing Challenges
Re: First Build : Plywood Sourcing Challenges
#31 Post by Bruce Weldy »
Joman116 wrote: Sun Dec 28, 2025 9:31 pm
Bill Fitzmaurice wrote: Sun Dec 28, 2025 8:05 am 1HP lacks power, 1/4" bits don't work well. I recommend this: https://www.ryobitools.com/products/332 ... Ruu_JQBXsz
Ended up buying a Bosch 1617EVSPK 2.25 HP from amazon as I had giftcard. Seems to be a standard proven unit thats been around for awhile, reliable.
All right next up is the circle jig..point me in a direction Bill!
That is the exact router kit that I've had for years. I love it. The wooden handles feel great and it's very versatile. Get you a Jasper Circle Jig and you're in business. I tried building my own circle jig first and used it a while, but the Jasper is so much more precise and faster to use.
Shoot.....all this tool talk makes me want to build something.
Joman116
#32 Post by Joman116 »
Bruce Weldy wrote: Mon Dec 29, 2025 9:47 am
Jasper circle jig.. Got it. I'll research that one. Got alot of giftcards this holiday so obviously it needs to go to my bfm subwoofer project
QSC 1804 Amp
#33 Post by Tom Smit »
Do it, do it, do it! LOL.
#34 Post by Bruce Weldy »
Tom Smit wrote: Mon Dec 29, 2025 10:25 pm
Whew! Thank goodness I came to my senses.....
I just got through repairing my 40 year old air compressor....that should hold me for a while. I'll stick to fixing gear and building cables. Stuff I can do sitting down.
#35 Post by Tom Smit »
:D
Joman116
#36 Post by Joman116 »
What jasper jig do you recommend? Model 290 or 200? I think the main difference the 290 can cut smaller (1 1/2").
QSC 1804 Amp
#37 Post by Bruce Weldy »
Joman116 wrote: Mon Jan 05, 2026 12:10 am
Didn't know they had so many models now! If you don't anticipate using it every day and you take care of your tools, the regular (not Pro) should be great with a lower price tag. As far as the size holes....I think the smallest diameter I ever used mine for was about 5.5in for the SLA Pro. I can't imagine ever needing a 1.5" hole. And if I do, I'll use a forstner bit.
So, I'd go with the cheapest one that Jasper makes. The 200 looks good and that's cheaper than what I paid years a go.
Joman116
#38 Post by Joman116 »
Bruce Weldy wrote: Mon Jan 05, 2026 11:51 am
Ending up finding a deal on ebay (had ebay giftcards) for the "Jasper 200 PRO LTD ": https://jaspertools.com/products/jasper ... -18-3-16-d
Ended up costing $36 for open box, not bad!
Also decided to hop on a sander.."Makita 5" Random Orbit Sander BO5041K"
So now from a tool perspective I've got..
-SKIL Table Saw 10" TS6307-00
-Makita Circle Saw 7 1/4" 5007mg (wired)
-60 tooth blade for 10" and 7 1/4"
-Makita 5" Random Orbit Sander BO5041K (wired)
-Bosch Router 1617EVSPK (wired)
-Makita Sander BO5041K
-Jasper Circle Jig 200 PRO LTD
Ryobi Impact and Drill Drivers (wireless)
From a materials perspective, I've got
-Enough russian birch for 2-3 subwoofers
-Enough Kappalite 3012LF drivers for 3 subwoofers
I am contemplating to buy the "hardware kit" from leland at speakerhardware.com. Would make my life a lot easier as its my first build and wouldn't have to go hunting around...
oh yeah I need to get a speed square! Any other things I'm missing?
QSC 1804 Amp
#39 Post by Tom Smit »
I haven't checked if you know how to operate a table saw. If you don't, this video is quite discriptive, and should be followed before cutting any wood. Way back when, I found it quite handy. A properly adjusted saw blade is much safer to use than one that is not..
Do the same for how to use a router.
Joman116
#40 Post by Joman116 »
Tom Smit wrote: Mon Jan 05, 2026 11:07 pm I haven't checked if you know how to operate a table saw. If you don't, this video is quite discriptive, and should be followed before cutting any wood. Way back when, I found it quite handy. A properly adjusted saw blade is much safer to use than one that is not..
Please do share the link. First time table saw/router user. Much to learn. Not cutting anytime too soon..need to prepare mentally and align the stars first...
QSC 1804 Amp
#41 Post by Tom Smit »
Oopsies, I forgot to put the link in that post! Sorry.
Tablesaw.... https://www.youtube.com/watch?v=rYuK3AxP1EA
Router...https://youtu.be/bG2ldmVt56Y?si=u665nVFkEJublGau
https://www.youtube.com/watch?v=8Vl8Jbw3cSk
Search on the net for other examples of how to use a jigs and sleds.
how to use a router for beginners ...is a phrase that I used in the search bar.
Joman116
#42 Post by Joman116 »
Tom Smit wrote: Tue Jan 06, 2026 10:54 pm
Thoughts on purchasing a saw horse? I dont think the SKIL tablesaw alone is sufficient to rip the larger panels...would need a saw horse to support. Also saw horse can be a work bench to work off of. Below example (but I can get it for alot cheaper)
https://www.walmart.com/ip/Worx-WX064-P ... 5594213802
QSC 1804 Amp
#43 Post by Tom Smit »
This might be cheaper if using a circular saw to break down plywood sheets. https://external-content.duckduckgo.co ... ipo=images
After breaking down the sheets into slightly oversized panels, run the panels through the tablesaw to make them the correct size with the correct angles.
Joman116
#44 Post by Joman116 »
Tom Smit wrote: Wed Jan 07, 2026 10:35 pm This might be cheaper if using a circular saw to break down plywood sheets. https://external-content.duckduckgo.co ... ipo=images
Thanks. I ended up buying the worx saw horse I linked. It can be setup the way u pictured actually. Now still deciding on build..
Imleaning on building two more t39 (I have 2 right now) vs t45. More cabs would give a bit more extension. I'm mostly recorded music for my larger 400 plus events. Plus the efficiency of these is nuts..
QSC 1804 Amp
