T48 Setup
Keryn O'Shea
T48 Setup
Good morning,
I hope you guys are doing well,
would 6xT48s be able to be deployed in these configurations successfully outdoors when roadies or a forklift are unavailable for V-Plating?
https://www.prosoundweb.com/a-practical ... -arrays/2/
I'm yet to learn how to use delay. Thanks Seth, for posting this info originally
Re: T48 Setup
Those patterns are with wide arrays with separated cabs. They don't apply with closely placed cabs, which act as a single source.
Re: T48 Setup
I've always wanted to do firsthand testing of all that stuff, but have never had that many subs at my disposal.Keryn O'Shea wrote: ↑Fri Sep 27, 2024 6:25 pm Good morning,
Keryn O'Shea
Re: T48 Setup
Ok, thank you Bill. What number of T48s would be considered a wide array when separated?Bill Fitzmaurice wrote: ↑Fri Sep 27, 2024 9:01 pm Those patterns are with wide arrays with separated cabs. They don't apply with closely placed cabs, which act as a single source.
Re: T48 Setup
Don't separate them, it only causes problems.
Keryn O'Shea
Re: T48 Setup
Roger that.
However If l had to separate the cabs to cover a wide audience, is this setup per side asking for more trouble? It would be convenient to have two platforms at different heights to stack the mains on, without needing scaffolding or ladders.
Re: T48 Setup
That's OK.
Keryn O'Shea
Re: T48 Setup
Excellent! Thanks Bill
Keryn O'Shea
Re: T48 Setup
Finally had the time & help to stack all 6 & V-plate today
Re: T48 Setup
I thought I felt a shift in the force the other day... explains that.
Re: T48 Setup
