Anyone have a DXF, DWG of the Beta 8a frame? Perhaps a PDF drawing of what the hole spacing is?
I have one for the Delta pro 8 and i'm thinking about upgrading drivers. I want to lay the bolt pattern and driver opening on top of each other and see what i'd be in for.
Beta 8a bolt pattern drawing
Re: Beta 8a bolt pattern drawing
It should be on the Eminence data sheet.
I was hoping for something like this, but I do see they indeed give a spec for the screw holes
