3010MB/2510 into J10L/DR250..?
Keryn O'Shea
#1 Post by Keryn O'Shea »
G'day,
if your future builds were J10Ls followed by DR250s for PA duty with subs (both CDs), and you had 3010MBs & 2510s sitting on the shelf, which driver would you load in which cab & why? There's pros & cons for both combo's.. l'm having trouble deciding.
Re: 3010MB/2510 into J10L/DR250..?
#2 Post by Bill Fitzmaurice »
The 2510 is a bit better in the low end, the 3010 a bit better in the high end. I'd go 2510 if you'll never use subs, 3010 if you will.
Keryn O'Shea
#3 Post by Keryn O'Shea »
Bill Fitzmaurice wrote: Sat Jun 08, 2024 7:09 am The 2510 is a bit better in the low end, the 3010 a bit better in the high end...
Excellent.. 2510 into the J10L, and 3010 into the DR250 then, thanks Bill.
